LUT Questions
OP (Company: Student) #4986964
I'm a student and i'm preaparing an exam and i have some question about
LUTs
1- How many memory case ( 1 bit) we have in a LUT with 12 inputs
2- How many of LUT-12 we must have for memorise a 64 bits variable
3- How many LUTs-12 we must have for memorise a 8000 variable of 64 bits
Thanks a lot
Guest #4987303
LUT means Look Up Table.
If you have 12 bit input, how many rows do you think can you address
with these 12 bit?
If you say, that there is only one output, how much different bits can
you "store" with one LUT.
Ok, this is more or less a rephrase of your questions, but you should
really think about your exams yourself and not ask for the solution.
OP (Company: Student) #4987328
> with these 12 bit?
i have my exam on september, and i don't have documentation ... so i
take previous exams and exemples and i ask question for understund how
it works
Thanks
Guest #4987383
I think he means a 12 input LUT. Which can be thought oft as a RAM with
1 Bit per adress. How many Adresses can you build with n inputs?
Moderator (Company: Titel) #4987615
Then its easy...
2^12
64
#4987637
Edit:
64
This i don't understand. I think of an 12-input lut as a RAM with 12bit
adress. So it can store 2^12 Bits.
OK with one fixed 12bit adress you always adress the same bit in this
"RAM". Is this how it is done? 64 LUTs where every LUT stores just one
bit at a fixed adress? Why not store all 64Bits in the 2^12 Bits RAM?
Because it can only output one Bit at a time?
Edit:
Now i understand. Had a look at SLICEL and SLICEM and both have a single
bit Output so indeed you have to use more LUTs in parallel.
Moderator (Company: Titel) #4987683
You got it.
A 64 bit variable is 64 bits wide and to store 64 bits in parallel
you need 64 LUTs. Otherwise you must access each bit one after the
other.
In fact with 64 of those 12 input LUTs you could store 4096 of those 64
bit variables. But that was not the question... ;-)
OP (Company: Student) #4988106
Lothar M. wrote:
> Then its easy...
> 2^12
> 64
> 2
For the 3 question why not 64*2 Lut=128, beacause with 64 of those 12
input LUTs you could store 4096 of those 64  bit variables
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
