If or else if? Which is faster?
Guest #4985100
In a Verilog/VHDL design, Say that you have n (any number) completely
mutually exclusive events i.e. the events never occur simultaneously and
there is hence no priority associated with any event.In such a scenario,
what would be faster?
if (condition 1)
if (condition 2)
if (condition 3)
--------   OR  ----------
if (condition 1)
else if (condition 2)
else if (condition 3)
In my opinion, I think the simple ifs would work out better since the
priority doesn't have to be checked and would infer less hardware.In C
or MATLAB, the opposite may be true because if condition 1 turns out to
be true then all remaining conditions can be skipped by using else if.
My question is specific to VERILOG/VHDL.
Guest
its not so much a question of speed, but the fact that multiple
consecutive if-statements are another contruct than an "if .. else if"
block.
consecutive if's are executed each one by one, while an "if .. else if"
block is finished if one condition is met.
Guest
I get that.It is not a matter of speed, but what would infer simpler
hardware? I guess by speed I meant fewer gates and less
hardware/combinational logic.
Guest
Code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity test is Port(
  in_a: in std_logic_vector(3 downto 0);
  select_a: in std_logic_vector(1 downto 0);
  out_a: out std_logic;
  in_b: in std_logic_vector(3 downto 0);
  select_b: in std_logic_vector(1 downto 0);
  out_b: out std_logic);
end test;
architecture Behavioral of test is
begin
process (select_a, select_b) begin
  if select_a = "00" then out_a <= in_a(0); end if;
  if select_a = "01" then out_a <= in_a(1); end if;
  if select_a = "10" then out_a <= in_a(2); end if;
  if select_a = "11" then out_a <= in_a(3); end if;
  if    select_b = "00" then
    out_b <= in_b(0);
  elsif select_b = "01" then
    out_b <= in_b(1);
  elsif select_b = "10" then
    out_b <= in_b(2);
  elsif select_b = "11" then
30
    out_b <= in_b(3);
31
  end if;
32
end process;
33
34
end Behavioral;
Guest
Thank you for your input! I plan on doing something similar in Quartus
Prime and Xilinx ISE.
Thank you!
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
