Vivado warning for RAM component
OP #4984792
Hello guys..I have a pretty big project implemented and while it works
perfectly on Active HDL, on FPGA board it works only partially.. the
main idea is that I noticed that it doesn't read from 2 RAM components
that I created (in the attachment I provided one of them because they
are the same, only different informations in my_ram) and I suspect it
has something to do with this warning that I get during synthesis:
[Synth 8-327] inferring latch for variable 'my_ram_reg[1]'
["C:/My_Designs/yessir/bancomat/src/RAM-PIN.vhd":25] ( and it happens
from my_ram_reg[1] to [7] ).. what I'm trying to do is read the
information from that array that I created and use it in a process.. for
example, the number that I read from this RAM is used in an addition. I
can provide more files if needed...sorry for bothering but right now I'm
just learning VHDL
EDIT: I'm trying to link RAM component to read from it like this:
INTEROGARE: RAM2 port map (index,'1','0',"0000000000000000",suma); and
on the displays it shows data_in value... if I modify the last bit with
'1'.. it shows 0000000000000001
Guest #4985405
process(cs,adress,data_in,we,my_ram)
You are using a process without a clock. This is fine, but the
sensitivity list is only used in simulation.
The warning
tells you, that because of no clock you get a latch (and the toolchain
will not use BlockRAM or FFs).
So in Hardware
if cs='1' then
  data_out<="1001100110011001";
else
  if we='1' then
    data_out<=my_ram(to_integer(unsigned(adress)));
  else my_ram(to_integer(unsigned(adress)))<=data_in;
    data_out<="1101101011011010";
  end if;
end if;
runs parallel all the time. So if cs = '0' and we = '0' data is written
to RAM. How did you test ist? If you know what you do this might be ok.
Moderator (Company: Titel) #4985489
Tudor I. wrote:
> sorry for bothering but right now I'm just learning VHDL
You must distinguish between "VHDL for simulation" and "VHDL for
synthesis". For the first one you can use almost all of the VHDL syntax
elements.
And for the second one you must read in the synthesizers manual what 5%
of "the VHDL language" you can use to describe hardware in a FPGA or an
ASIC.
If you want to infer RAM, then read the according chapter in the
synthesizers manual, and write it the very same way in your code. Then
maybe you will get what you want: a RAM block inside the FPGA is used.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
