sdram problem in vhdl quartus
Guest #4982539
Hi, sorry but without a more detailed problem description one can only
guess so.. I don't know the de2 board, I got the DE0-nano board and on
that the clock for the sdram chip had to be shifted about -54 degrees to
make it work, maybe with the your board it is the same. The datasheet of
the sdram controller ip, if I remeber correctly, also says something
about a fmax of 100MHz for stable design, more speed might be possible
but I never tried. The other tricky thing is the avalon fabric itself I
was wrestling with the sdram controller ip for quite some time and found
you can not only rely on the waitrequest signal to start your read or
write action, you have to enable read or write and than you check the
waitrequest signal it sounds strange but thats the way I got it working
reliably... hope I could help.
OP #4982706
thank you for your answer. as you say relying the waitrequest is a wrong
thing to do. i managed to make it work but now i had a performance
issues bu i think i can figure out how it works. thank you you gave me a
nice piece of idea.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
