Error when trying to synthesize
Guest #4982000
Hello... I'm trying to implement a design which increases a 16-bit
vector on each 4 bits, depending on a selection and button which
increases the respective 4-bits which are selected by the selections and
im getting the following error when im trying to synthesize it:
Line 21: statement is not synthesizable since it does not hold its value
under NOT(clock-edge) condition
Please help me to resolve this
Moderator (Company: Titel)
A clock in a FPGA is described with 'event. Have a look how others use
this attribute, or read your synthesizers manual how to invoke clocked
flipflops.
BTW: never use a badly bouncing button as a clock source. In a FPGA
design usually the one and only clock has something around 50Mhz. Use
this clock to sync in the bouncing button and then and after debouncing
do an edge detection on that signal. Then you have a perfect synchronous
design.
Guest
at first you should rewrite your code like this:
if clk'event and clk = '1' then
  case
  end case;
end if;
Tudor I. wrote:
> EDIT: I tried using debouncing on that button
How?
Debouncing simply means: check for a stable signal for e.g. 20ms. And
then add an edge detection for the counting...
Something like this:
http://www.lothar-miller.de/s9y/archives/3-Tastenentprellung-mit-Schieberegister.html
And as I said: look how others did it. Look a ten designs and do it like
the majority does it. Then you are not that far away from a
synthesizable result.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
