effitient code
Guest #4970610
hi evryone,
is there any best way to check if the difference between two integers is
greater than a threshold
i find the code witten by me is quite big..need ur inputs thanks
if((unsigned(a)>unsigned(b))and((unsigned(a)-unsigned(b))>=500)) or ((unsigned(a)<unsigned(b)) and ((unsigned(b)-unsigned(a))>=500))then
---my code
end if;
#4970685
Absolute value of difference of absolute integer values? Depending on
your compiler it may recognize the pattern abs(abs(a)-abs(b)) and do
some sign bit optimization. If you need to be certain of clock cycles:
do it in assembler, otherwise trust the compiler.
#4970695
It seems as if you could simply subtract b from a and then somehow
ignore the possible negative sign if the first value was smaller than
the second. Check only if the difference is bigger than 500.
Moderator (Company: Titel) #4970698
What means "big" here?
Are those two integers unsigned integers (aka naturals)?
> ---my code
> end if;
With integers simply this:
if abs(a-b)>=500 then
end if;
Boris O. wrote:
> If you need to be certain of clock cycles: do it in assembler
We are in real hardware here. It is done in one clock cycle... ;-)
H-G S. wrote:
> and then somehow ignore the possible negative sign
Have a closer look at the chapter "twos complement and integers". There
is no such thing like a "negative sign" on a integer. All of the bits
are "signs". So you cannot "cut away" or "simply ignore" the sign. Look
at this "8-bit-integer":
 2 = 00000010
 1 = 00000001
 0 = 00000000
-1 = 11111111
-2 = 11111110
See it: you don't see a "negative sign"
#4971103
As i read your code again now it seems it lacks something. Does it work
the way it is now ?
To me it seems you have to implement more code for this task, especially
for the case that the subtraction causes a rollover. Simple asking if
the first value is bigger than the subtracted one does not always mean
that the subtraction of 500 does not cause a rollover.
But it may be that the higher language compiler has a solution for this
problem and counts that all in (the "bigger than"-routine for example
could automaticalle handle rollovers).
Moderator (Company: Titel) #4971639
nick wrote:
> they are declared as standard logic vectors.
Then why do you write somewhat about "integers"? An integer is a
predefined data type in VHDL. Never ever call a std_logic_vector an
integer!
Ok so you must use the numeric_std.all and write it that way:
if abs(unsigned(a)-unsigned(b))>=500 then
end if;
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
