AVR Mega328 does not exit the test mode
OP (Company: Advanced user) #4970238
Hi
I have a Transistor Tester based on the originals circuit diagrams and
code under the mikrokontroller.net site.
It worked well for so many hours. I had measured many unsorted
capacitors transistor and coils last weekend.
While was working it started moving slowly between menu's, as an example
I wanted to move from Capacitor menu to coil menu and then to
transistor. Moving out and into the menus was a bit slower than before.
So I decided to reboot the Tester. On Reboot it delayed popping up the
first screen around 1.5 minutes.
Finally I got the message on the LCD
Cell
29mv   2mv
VCC=4.98 Volts. Then immediately after the two minutes the messsage:
on the LCD:
Short Probes ! <Blinking for more than 2 minutes contnuously>
After the two minutes have elapsed, the LCD showed:
1 --||-- 3 > 100nF
So I Inserted a 100nF. It took the tester 3 minutes refreshing the
screen coming back to the same
1 --||-- 3 > 100nF. Finaly after 2 or 3 minutes it counted the Capacitor
right, and exited displaying on the LCD
FW Version 1.2k
Tests Ok
Pressing the button will reboot or shutdown.
Pressing the button will enter the same diagnostics again.
Is it the code gone bad ? The Schematic features all the new revised
parts by Karl-Heinz.
Troubleshooted all Transistors and replaced them anyway with 2 2N3904
(NPN) and 1 2N3906 (PNP)
Has anyone else faced this problem  or similar ?
On the board there is an smd device P6KE6V8A and TL431 for Reference
2.49v and another transient device protection smd SRV05−4
I am suspecting that one of these has gone bad ! Any ideas welcome.
Thank you
Enjoyed reading the manual.
Guest #5010688
yes I managed to cause the same problem on 3 of my testers, and after
receiving the 4th one i figured it out and fixed all of them XO go
figure. It's the 6 pin ESD protection In my case I tried to float the
ground on the pwm output +6V(beginner obviously) and the supply for that
chip, MC5 i believe are the SMD marks I have datasheet if you need it,
has narrow max voltage between its supply rails (+/-5 iirc)
Good luck!
OP (Company: Advanced user) #5764791
Hi
Yes I can provide some description.
On this transistor tester, there is a spark / ESD protector chip which
is basically a diode protection immediately after the probes. Its an smd
chip and what it does is to protect from transients esd from
electrolytic caps etc  the main circuit. Its all diodes. One of the
diodes has gone bad shorting out the probes hence all the boot up
delayed response from the At Mega. I completely removed the chip that
cured the problem. However be twice as cautious now. The chip am
referring to is SRV05−4.
Thanks for responding
#5792778
Dimitris K. wrote:
> Hi
Just saw your answer. Thank for your reply. I removed completely the
srv05-4 chip but this did not solve the problem in my case. I even
reprogrammed the MCU. I will check all the components in case there is a
bad one.
John
Start a new thread
