Want to try out GCC 7 (experimental version) on your ARM microcontroller?
OP #4968333
If you're very impatient waiting for the full GCC 7.1.0 release
(expected this month), you can try experimental GCC 7 version with your
ARM microcontroller right now (;
$ arm-none-eabi-gcc --version
arm-none-eabi-gcc (bleeding-edge-toolchain) 7.0.1 20170402 (experimental)
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
https://github.com/FreddieChopin/bleeding-edge-toolchain/tree/gcc-7-experimental
The script is able to produce a working toolchain for Linux. It is also
possible to cross-compile a toolchain for Windows (32-bit or 64-bit) -
either in Linux or in "Bash on Ubuntu on Windows" (I've heard it can be
done, but the process is painfully slow - who would expect that? (; ).
I've tested that toolchain briefly and it appears to work fine (;
OP #4969411
The term "benefit" is highly subjective and I wouldn't want to go into a
debate about who likes what and especially about who dislikes what and
thinks it it stupid, worthless and useless (; ...
However GCC 7 does promise some interesting things - at least
interesting for me (; This would be C++17 support, improved LTO and
better warnings. It obviously fixes some bugs from the previous releases
and I personally have a strong tendency to bump into these bugs (;
Some people may find the new "-mpure-code" option interesting - it
allows one to generate a binary which can be used with the most strict
"proprietary code protection" mechanisms found on some chips, which
cause some sections of the memory to be "execute only", which means that
all reads from that section are forbidden. This obviously also includes
reads of literals by the very same code that is placed in that region,
so such firmware needs this new special option.
There is also one more thing worth mentioning. This is the first GCC
version to support ARM microcontrollers without any patching! Previously
- for all these years - GCC had the multilib config for ARM
microcontrollers only because the people who produced binaries patched
the sources to add these multilibs. If you would take a "stock" GCC
release before version 7, then without patching all you could get is a
toolchain that produces firmware for ONE_ architecture with _ONE
configuration of thumb/ARM and ONE FPU configuration. With GCC 7 this
finally changes - if you examine the script that I posted, you'll notice
that it performs absolutely no modifications to any package it
downloads.
But - as I wrote in the first paragraph - all of that is highly
subjective. If you are perfectly happy about your current toolchain and
you have absolutely no urge to upgrade it - fine (; Then this topic is
simply not for you (; But some people really like bleeding-edge
software. I do and I think I'm not alone <:
OP #4997182
Stable GCC 7.1.0 was released yesterday, and you can already use it with
your ARM microcontrollers (;
Components:
- gcc-7.1.0
- newlib-2.5.0.20170421
- binutils-2.28
- gdb-7.12.1
- expat-2.2.0
- gmp-6.1.2
- isl-0.18
- libiconv-1.15 (Windows only)
- mpc-1.0.3
- mpfr-3.1.5
- python-2.7.13 (Windows only)
- zlib-1.2.11
arm-none-eabi-gcc (bleeding-edge-toolchain) 7.1.0
You can download Windows binaries (both 32-bit and 64-bit) and the Linux
script from my personal website - http://www.freddiechopin.info/en >
Download > Software > bleeding-edge-toolchain
Start a new thread
