VHDL error “Process clocking is too complex.”
OP (Company: none) #4967758
Hello everyone I recently started coding in VHDL(code here is of T flip
flop) and I'm having an error which says "Process clocking is too
complex", and this is with the first code attached below and
surprisingly I the solution too. But I don't know how it worked, code
without error is Second code. I googled about the error for half hour
but couldn't find the satisfying reason. Please help.
First code:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY t_ff IS
    PORT(t,clk,rst:IN STD_LOGIC;
         q,q_bar:OUT STD_LOGIC);
END t_ff;
ARCHITECTURE t_ff OF t_ff IS
SIGNAL temp: STD_LOGIC;
BEGIN
    PROCESS(clk,rst)
    BEGIN
        IF(clk='1' AND clk'event)THEN
            IF(t='1')THEN temp<= NOT temp;
            END IF;
        ELSIF(rst='1')THEN temp<='0';
        END IF;
        q<= temp;
        q_bar<= NOT temp;
    END PROCESS;
END t_ff;
Second code:
LIBRARY ieee;
ENTITY t_ff IS
END t_ff;
BEGIN
    PROCESS(clk,rst)
    BEGIN
        ELSIF(clk='1' AND clk'event)THEN
            END IF;
        END IF;
        q<= temp;
        q_bar<= NOT temp;
    END PROCESS;
END t_ff;
Moderator (Company: Titel)
Rocking S. wrote:
> I'm having an error which says "Process clocking is too complex"
What part of the toolchain reports that error?
Rocking S. wrote:
> code without error is Second code
So the problem is in the order of clock and reset in the first one. And
with a closer look it's easy to see: you want a flipflop where the clock
is dominant against the reset. There is no such component inside a FPGA.
To get synthesizable code you must write it in a way the synthesizer is
able to transform to hardware.
BTW: do you know a flipflop with such a behavior at all?
Guest
No, but as I wrote earlier I just started learning VHDL so I was trying
out few things. Yes I know I'm trying stupid things. But hey can you
tell me how should I start learning this language?
The best way is to look how others did it. And to look for the
synthesizers manual. Because out of the 100% VHDL running well on a
simulator only about 5% will be synthesizable.
So, VHDL for FPGA is much different than VHDL for simulation. The first
one is about 5% of the second one.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
