Multi functional push key.
OP #4960579
Hello all,
I'm new to this forum so any help is appreciated. I am using a soc-de1
dev board and on this dev board there are 4 push keys but I want to use
only one push key that can activate different functions depending on how
many times I activate that push button. For example say I want to
control a fan with 3 different settings by only using one push key. The
first setting is activated if the push key is activated once, second
setting if activated twice, and third setting if activated three times.
What would be a good approach to creating this?
Thank you.
Guest
Debounce this button, and count the rising edges in a time window.
Moderator (Company: Titel)
The definition is ambiguous:
Lets say "speed" instead of "setting" and you have threee speeds "off",
"slow" and "fast".
Now we have the first approach:
When the fan stands still, and then when the key is pressed once the fan
should switch to speed "low". Now it will switch to speed "fast" when
its pressed one again one minute later. And to "off" when its pressed
again one minute later. To conclude: it will cycle through the three
speeds like this (p=press and release key, -=one minute, o=off, s=slow,
f=fast):
key    ---p---p--p--pp----p---ppp---p--pp---
speed  ooossssfffooosfffffoooosfoooosssfoooo
Or the second approach:
When you press the key only once should it switch "off". But when you
press the key twice in lets say less than one second then it should
switch to "slow". And if its pressed three times in one second then it
switches to "fast". So the action will be like this:
key    ---p---pp----p---ppp---p--pp---p---
speed  oooooooosssssooooooffffoooossssoooo
I would expect my fan to behave like approach one. How should yours?
However: the first step is (as already said) always the same sync the
button to the FPGA clock and afterwards debounce the signal and perform
an edge detection to it.
What comes next depends on the desired behaviour:
1. When you simply have to cycle through the three speeds, than add a
counter from 0 to 2. Wrap it around when it reaches 2.
2. When you must implement a behaviour like approach 2, then count the
key presses and start a timeout counter of eg. 500ms with each keypress.
When the timeout counter reaches its final value, then that means that
the last counter value is valid and should be used as the new speed.
BTW: which HDL do you use?
OP
Sorry for the ambiguity I should have been more clear. Mine would
function like the second option which you pretty much nailed. I had a
similar approach but was having problems visualizing my implementation.
Thank you so much this was very helpful and I use vhdl along with
quartus and modelsim.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
