can 2 Arduinos communicate via USB ?
Moderator (Company: Titel) #4939428
Gerald Trost wrote:
> I would connect 2 Arduino Nano to a USB HUB on my computer.
> Is there a way the 2 Arduinos could communicate in this configuration
> via the existing USB cables ?
No, because the hub is not able to route any information directly from
one of the end points to the other. You must communicate between the
arduinos over the PC: one sends its data to the PC, where a piece of
softwar eis running that puts that data over to the other arduino.
Guest #4939602
sweeter ...
YES ... if you use the PC as a relay station. Write a driver which
receives on on virtual comport and relays the data to the other virtual
comport.
Start a new thread
