Writing Testbench for Bidirectional/Inout Port
OP (Company: None) #4930810
Hello! I have to write a testbench for I2C. I have an inout SDA port,
which I drive to either zero or high impedance state in the module.I
want to make sure that on the 9th clock cycle, when the SDA port is
driven to a high impedance state for the slave to issue an acknowledge,
the test bench drives the port low, indicating successful
acknowledgement by the slave. Currently, I know when I want to drive the
port low, this cycle is marked by an IO signal in simulation which goes
high on the 9th clock cycle.
The function should be something like this :
//reg IO; //IO is controlled in the testbench, not exported from module.
 if (IO)  SDA = 1'b0;
 else     SDA = SDA;
The following approach did not work.
 assign SDA = IO? 1'b0 : SDA;
Guest #4930823
The problem may be that you never set SDA = 1'bZ when IO===0. So your
SDA signal is always driven by the test bench. ( I am not sure if 1'bZ
is the correct notation for high impedance in Verilog, you have to look
up)
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
