Warning: NUMERIC_STD.">=": metavalue detected
Guest #4928452
helo members ,
i get this warning in questasim ,
Warning: NUMERIC_STD.">=": metavalue detected, returning FALSE,
here count is unsigned vector ..
for i in 0 to 2 generate
process(clk,rst)
 if(rst)then
   count<=<=(others=>(others=>'0'));
 elseif rising_edge(clk)then
  if((count(i)>=to_unsigned(0, count(i)'length))
 end if;
end if;
end process
end generate
how can this be solved. i assigned initial values dueing signal count
initialisation and during reset still gettind same error
Moderator (Company: Titel) #4928468
Whats that?
The problem may be located somewhere outside the posted code snippet.
Very interesting are the first 5 lines of your VHDL code. So simply
attach your VHDL file as a *.vhdl file.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
