File system in vivado SDK
Moderator (Company: Titel) #4918246
Sai S. wrote:
> it is not giving me any results.
What does it do instead? Does it run? Does it report any kind of
error? Do you at least get a valid filepointer?
> Can i use file systems in SDK?
Does your hardware support any kind of memory on which a file system
can be implemented?
> fp = fopen ("C:\\Users\\Sairam\\Desktop\\OUTPUT\\file.txt", "w+");
Ouch, ouch. Does your zynq hardware have a drive "c:\"?
As far as I see: you have a big problem about understandig where your
software is running actually.
It is NOT running on your PC with your drive "C:\Users\...". Instead you
develop software thats running on a zynq-board on your table without any
> Can someone please tell me why it is so?
Become clear about the design flow and the target. At the moment you are
on the very wrong track!
OP (Company: sssihl) #4918358
HI
thanks for the reply. I am new to this area. I got a fair idea of what
is happening. Basically i need to process a file of size 25MB. If i
store that in a header file in vivado SDK, the compiler hangs. So i was
exploring these options.
Do you have any idea regarding this.(I am using zed board (zynq 7000)
for processing)
Moderator (Company: Titel) #4918389
What kind of data is in the file? What kind of process must the FPGA
perform?
Usually it goes like this: you read the file in the PC and send a
datastream via Ethernet to the FPGA. The FPGA does some calculations and
sends the result back to the PC. There you store it an the hard disk.
> If i store that in a header file in vivado SDK, the compiler hangs
If you have the MicroZed at least, then you have a microSD port. And
there should be some samples how to access it.
> I got a fair idea of what is happening.
To be honest: I'm not that sure at all...
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
