Forum: FPGA, VHDL & Verilog 32-bit adder question
von DSP_Arch_Student (Guest)
Hello,
I am trying to write a code for a 32-bit adder. I am having trouble
where the carry in signal is not be registered at all. Here is my code,
can you guys give me some insight as what is wrong, I think I might not
be understanding some fundamental concepts associated with VHDL. I am
new to VHDL, so I welcome all sort of critiques.
Thanks,
D_A_S
Code:
LIBRARY ieee;
use ieee.std_logic_1164.all;
ENTITY hmk2_32bitAdder IS
  PORT(a, b : IN std_logic_vector(31 downto 0);
     c : IN std_logic;
     result : OUT std_logic_vector(31 downto 0);
     cout : OUT std_logic);
END ENTITY hmk2_32bitAdder;
ARCHITECTURE adder_32bit OF hmk2_32bitAdder IS
  SIGNAL c_internal : std_logic;
  BEGIN
    P1 : PROCESS (a, b, c, c_internal)
     BEGIN
       c_internal <= c;
      for i in 0 to 31 loop
        result(i) <= a(i) xor b(i) xor c_internal;
          c_internal <= (a(i) and b(i)) or (a(i) and c_internal) or (b(i) and c_internal);
      end loop;
      cout <= c_internal;
   END PROCESS P1;
END ARCHITECTURE adder_32bit;
An adder is a completly registerless, combinatorial design. So is yours:
no clock, no registers.
And now: what do you mean with "not registered"?
One major flaw in your design ist, that you don't know about how signals
behave in a process. They keep(!!) their value throughout(!!) the whole
process. And at the end of the process they get the last assigned value.
Think about that.
Lets start here with c_internal='0' and c='1'. On the right side of all
the assginments througout the process c_internal is '0':
     BEGIN
       c_internal <= c; -- c_internal gets a new value that will possibly be transferred at the end of the process
        result(i) <= a(i) xor b(i) xor c_internal; -- c_internal IS '0' HERE
          c_internal <= (a(i) and b(i)) or (a(i) and c_internal) or (b(i) and c_internal); -- c_internal IS '0' HERE, it may get a new value at the end of the process
      end loop;
      cout <= c_internal; -- c_internal IS '0' here, so cout is '0' also
   END PROCESS P1; -- And finally c_internal here gets the last assigned value from three lines above
In this case here c_internal must be a variable. Variables virtually
take over the assigned value "immediately". Lets start again with
c_internal='0' and c='1':
  BEGIN
     variable c_internal : std_logic;
     BEGIN
       c_internal := c; -- always initialise the variable!
      for i in 0 to 31 loop -- surprise, surprise: now HERE c_internal IS '1'
          c_internal := (a(i) and b(i)) or (a(i) and c_internal) or (b(i) and c_internal);
      end loop;
      cout <= c_internal;
   END PROCESS P1;
But be aware that variables in processes are not like variables in C
programs (as VHDL is not a programming language, but a description
language. just keep it in mind, you will find out further on)...
von Sym (Guest)
Apart from this 'educational' implementation, one would normally use
ieee.numeric_std, and the '+' operator. Simply because it is much more
readable, and - this is the main reason - the compiler can map it to
arithmetic hardware which is faster and smaller.
von Sigi (Guest)
Registering all carries (+clock) would imply a
pipeline design, but I guess that's not
your aim.
The problem is, that you only use ONE!
signal for all carries, but incl. input Carry
you have 32 carries. Declare a new vector cy
and assign "cy[0] <= c" and in each stage
"cy[i+1] <= (a(i) and b(i)) or (a(i) and cy[i]) or (b(i) and cy[i]);
von Sigi (Guest)
sorry mistake, incl cout you need 33 carries:
cout <= cy[32]
@Sigi, @lkmiller,
I know this is a little late on the reply, but thanks you guys for the
help! I know what I did wrong now, a semester after the class is over!
:D
As long as I know what I did wrong, I'm happy. So, thanks for the help
again!!!
