Generating a square wave from input push button
Guest #4917893
I am programming an FPGA that uses push buttons as input signals. I am
programming a finite state machine with 11 states that transition from
state to state using specific button presses. For example, in my design,
state 0 goes to state 1 using button1. This is the same transition case
from state 1 to 2 and from state 2 to 3. This state transition system is
implemented in my vhdl code using case statements much like the "switch"
statement in c++. I am lighting up certain LEDs in each state to keep
track of which state the board is currently in. My issue is that when I
press button1 while in sate 0, the board shows that it has moved to
state 3. What i think is happening is that it is indeed going to state 1
and 2 but the same button press in state 0 is also being read in state 1
and 2. This happens so fast that the boards doesnt have enough time to
show the LED indications for state 1 and 2. It stops at state 3 because
state 3 moves to state 4 using a different button. So my question is,
how do I make the button press signal have a rising edge and a falling
edge such that a single button press is read only in one state and not
the ones that follow it? The press button signals are debounced but this
only makes the signal a uniform wave. Any help is appreciated, thanks.
I attached my vhdl code.
The "btnC, btnL, btnR,..." are the push buttons.
Guest #4917977
You could insert additional states which are waiting for button release.
For instance, instead of transitioning directly from state 0 to 1,
insert another state which is waiting for button release and then
switches to state 1.
Moderator (Company: Titel) #4918557
    FSM: process(clk, my_btnC)
    begin
    if(my_btnC ='1') then
        my_state <= s0;
    elsif...
NEVER EVER use a async input directly as a reset source. You may
encounter spurious problems when leaving the reset. This is because
your FSM are some flipflops in reality. And the reset goes to their
reset input. When the reset is deactivated at the same moment (+-a few
ps) when a rising_edge on the lock occurs (and that is about 10..100
million times per second) then some of the FSM flipflops see a
deactivated reset and some not. And therefore the FSM starts with a
undetermined wrong state...
Run a simulation. And see how your code reacts to "short" and "long" key
presses.
Then you will find out that you edge detection (and before that
debouncing) on each button input.
Start a new thread
  • [vhdl]VHDL-Code[/vhdl]
