Reset on LPC1768
OP (Company: Coinel Technology Solutions) #1849444
Hello,
I am using LPC1768 and programming it using ISP. What i have observed is
that the programs that i load work fine but when i repower the LPC
board, the code starts to work only after a reset.
The code executions should start after powerup.
Kindly let me know what could be the possible issue.
#1853278
Hello,
to me it looks like a problem with the power supply.
If you switch on the power, all the devices in your circuit draw
current. If this ist too much and the voltage drops below a certain
level, the controller might end up in an undefined state.
Solution might be too change something on your power supply. Or maybe
there is a parameter to delay the startup of your controller.
I hope this will help you!
Guest #1854376
Have you enabled the brown out detection? Another possibility is the
power supply: If you only switch off the power for a few seconds there
may be capacities in the circuit which holds the power on a sufficient
level. As a result the µC doesn't recognize the power loss.
Moderator #1854881
Are there any loops in the initialisation which wait for bits to be
set/cleared by the hardware (something like while
(!(SOME_REG&SOMEMASK)){;})? IF so, check with "LED-blink-debugging" if
the code "hangs" in such a loop. Did you try with the ISP interface
connected and disconnected. Did you check the VCC, BSL and RST levels
with a scope? Do you use code from NXP's CMSIS package to init the
clock-system? If not, you may at least do a few tests with the code from
the package.
OP (Company: Coinel Technology Solutions) #1855380
Mk Bit wrote:
> Hello,
Thanks for your response. Ya it looks like problem hardware only.
I have herewith attached the circuit, It would be great if you check
this circuit
The reset and isp circuit i have uploaded to this link
The RST# goes to controller pin 17.
OP (Company: Coinel Technology Solutions) #1855420
> the package.
Thanks for your reply.
There are no loops in the initialization.
I have checked the VCC, BSL, RST lines
BSL line: default -> 3.1v
          After ISP switch - 0 -> 3.1v (the value changes from low to
high)
Vcc line: Default -> 3.3 v
          After Reset - 3.3v
RST line : Default -> 1.7v
           After Reset - 0 -> 1.7v (the value changes from low to high)
RST out Line: Default -> 3.2v
            after reset - 0-> 3.2v (the value changes from low to high)
These lines seems to be working fine, Any suggestions to the possible
problem??
Guest #3500734
helloo
i have a challenge with lpc 1768 reset.
 in several case when i reset  this processor via  the  reset pin and
connect it directly to gnd the ic  will crashed and burnes.so that for
avoiding ic failing i should reset the ic reset pin via the resistance.
Please log in before posting.
or
Registration is free and takes only a minute.
Register now
