Forum: FPGA, VHDL & Verilog Misunderstood in Verilog basics?
von Lapo (Company: Radioteknos) (lapo)
I'm quite new to Verilog but I've some code working but from time to
time I got some uncompresible behaviour and I think I lake some knoledge
in Verilog.
Here is a quick example of a more complex project, it works with div2
module (/* go */) and don't with div5 module (/* no go */). Go / no go
means I got ssoc signal on LED2 debug output or not.
module test_div_1(
       /* iCEstick clk (12MHz) */
       input  clkin,
       /* 10MHz ref_in */
       input  ref_in,
       /* iCEstick leds */
       output LED_GREEN,
       output LED0, output LED1, output LED2, output LED3,
          /* ADC (DIV) spi */
   SB_PLL40_CORE #(
       .FEEDBACK_PATH("SIMPLE"),
       /* $ icepll -i 12 -o 30 */
       /* clkin=12MHz */
       .DIVR(0),    /* DIVR =  0  (div 1) */
       .DIVF(79),      /* DIVF = 79 (x80) */
       .DIVQ(5),    /* DIVQ =  5 (div 6) */
       /* main_clk=30MHz */
       .FILTER_RANGE(3'b001)  /* FILTER_RANGE = 1 */
       ) uut (
        .LOCK(LED_GREEN),
        .RESETB(1'b1),
        .BYPASS(1'b0),
        .REFERENCECLK(clkin),
30
        .PLLOUTCORE(main_clk)
31
32
33
34
   wire      main_clk;
35
   wire      ref_in;
36
   wire            soc;
37
   reg        ssoc;
38
   wire       spi_m_clk;
39
40
   /* soc generator (125kHz) */
41
   div80 d80_1(ref_in, soc);
42
43
   /* cs and clk generation */
44
45
/* -----\/----- EXCLUDED -----\/-----
46
   div2 div_spi_clk(ref_in, spi_m_clk); /-* go *-/
47
 -----/\----- EXCLUDED -----/\----- */
48
   div5 div_spi_clk(ref_in, spi_m_clk); /* no go */
49
50
   always @ (negedge spi_m_clk)
51
     ssoc<=soc;
52
53
54
   /* TODO: remove (debug) */
55
   assign LED0=spi_m_clk;
56
   assign LED1=soc;
57
   assign LED2=ssoc;
58
   assign LED3=1'b0;
59
endmodule /* # test_div_1 end # */
60
61
module div80(input in,
62
        output out);
63
64
   wire        in;
65
   reg          out;
66
   reg [6:0]        c;
67
68
   initial
69
     begin
70
  c=7'b0000000;
71
     end
72
73
   always@(posedge in)
74
     begin
75
  if(c>=79)
76
    begin
77
       c<=0;
78
       out<=1'b1;
79
    end
80
  else
81
    begin
82
       out<=1'b0;
83
       c<=c+1;
84
    end
85
     end
86
87
endmodule /* # div80 end # */
88
89
90
module div5(input in,
91
        output out);
92
93
   wire        in;
94
   reg         out;
95
   reg [2:0]        c;
96
97
   initial
98
     begin
99
  c=3'b000;
100
     end
101
102
   always@(posedge in)
103
     begin
104
  if(c>=4)
105
    begin
106
       c<=0;
107
       out<=1'b1;
108
    end
109
  else
110
    begin
111
       out<=1'b0;
112
       c<=c+1;
113
    end
114
     end
115
116
endmodule /* # div5 end # */
117
118
module div2(input in,
119
      output out);
120
121
   wire            in, out;
122
   reg             c;
123
124
   always@(posedge in)
125
     begin
126
  c<=!c;
127
128
     end
129
130
   assign out=c;
131
132
endmodule /* # div2 end # */
div80 module output works fine...
Am I wrong in something about wire/reg? Or what ever?
If it matter I'm using ice40stick and icestorm toolchain (yosys, nextpnr
and icepack).
Could you help me?
Thanks!
Lapo
von Rick D. (rickdangerus)
Lapo wrote:
> Go / no go
LED debugging may work with microcontrollers, but not with FPGA.
Learn to use a simulator for debugging your designs.
You are right. I should learn to use simulator and debugger in a lot
of situation.
In any case, the code was working but my logic design was wrong.
Thank you!
Lapo
