Forum: Analog Circuits speaker 4ohm 8 ohm maken?
von Erin (Company: avaq) (avaqsemi)
Hi
I have 4 pioneer300 watt car speakers that I want to use on a regular
(240 volt) surround amplifier instead of a car radio.
But on that amplifier it says on a bright red sticker: speakers NOT LESS
THAN 8ohm.
Is there a trick to make a 4 ohm speaker 8 ohm?
By putting something in between like a coil or something like that?
I've heard about it but never had to look into it.
In a box, these speakers have a great sound, which is why I want to use
them
: Moved by Moderator
von Peter D. (peda)
Simple put two 4Ω speaker in series.
von Gunnar F. (gufi36)
or to use 2:1 transformer
von Stefan F. (Guest)
But that redudes the power by 50% and has an effect on the sound
quality.
Anyway: this is better than having no sound at all.
> quality.
Not if the 8 ohms only amplifier has 600W per channel, than the voltage
is sufficiently high to drive 2 speakers in series.
But considering 300W Pioneer, these are for sure speakers that can only
handle 30Wrms maximum. So even a poor audio amplifier will have enough
driving capabilty.
Yes, it's surely worth a try.
von Εrnst B. (ernst)
Checking Pioneer Speakers advertised with 300W randomly:
Might even be 40 Watts.
https://www.pioneer-car.eu/de/de/products/ts-g1730f
>> ... mit einer Nennbelastbarkeit von 40 Watt ist maximal mit bis zu 300 Watt
belastbar ...
He has a surround amp, so he probably wants to use 4 channels for his 4
speakers. If stereo is enough, then yes, that's what I'd try as well.
von Joachim B. (jar)
Erin schrieb:
> I want
i want often so much, but never get it all. Life can be hard sometimes.
Better you want more easy thinks.
: Edited by User
