Forum: µC & Digital Electronics Turn Signal Relay
von Lernend B. (Company: KUKE Electronics CO., Limited) (lernend05)
I have a question, I have a 78 gmc tiltwheel pickup, its been shall we
say, upgraded to what ever fits the owner at the time, its rusty, but I
had everything working well, Then the blower motor seized up, so I
installed a new one, and it would not work, I had to hot wire it from
the fuse box, and then found out the turn signals wont work, I checked
bulbs, and wires, and put in a new switch, and still, they dont work, I
have power going into the switch, and the 4 ways work, and running
lights, and brake lights, but no power coming out of the switch, for
turn signals?, I tried 3 different flashers as well, Ground? bulb?. why
would both heater fan, and signals stop together? I have read the blog
about the turn signal relay.
https://www.apogeeweb.net/electron/the-best-guide-to-the-turn-signal-relay-flasher-relay-test-and-faq.html
But I am still confused...
Is  there anyone can help me? Many thanks.
von matzetronics (Guest)
That probably won't help much for your old car. I suspect an overload
problem when either the old or the new blower motor drawed current and
the fuse box became overloaded. You should probably dismount it and
examine it on the backside. Chances are that a contact or a wire has
gone awry and doesn't supply flasher and blower circuits. That could
well be before the current even flows through the fuses.
Old wires tend to become stiff and their insulation may disintegrate
when moved, so be careful.
Measuring voltage on the fuses may help to pin down the area where
voltage disappears.
And keep in mind that the old fuses themselves might have contact
problems. Pulling them and reinserting might help here, and cleaning
contacts might do, too.
A few drops of WD40 will not do any harm.
