I have a simple program. I am trying to input the counter output into a
memory address register and output the data that is in the memory
address register.
Memory Address Register Code:
1 | library ieee;
2 | use ieee.std_logic_1164.all;
3 |
4 | entity mar is
5 | port(
6 | mar_clk, mar_clr, mar_en : in std_logic;
7 | mar_datain : in std_logic_vector(3 downto 0);
8 | mar_dataout : out std_logic_vector(3 downto 0)
9 | );
10 | end entity;
11 |
12 | architecture behavioral of mar is
13 | begin
14 | process(mar_clk, mar_clr, mar_en, mar_datain)
15 | begin
16 | if(mar_clr = '1') then
17 | mar_dataout <= (others => '0');
18 | elsif(mar_clk'event and mar_clk = '1') then
19 | if(mar_en = '0') then
20 | mar_dataout <= mar_datain;
21 | end if;
22 | end if;
23 | end process;
24 | end behavioral;
Buffer4 Code:
1 | library ieee;
3 |
4 | entity buffer4 is
5 | port(
6 | buff4_en : in std_logic;
7 | datain : in std_logic_vector( 3 downto 0 );
8 | dataout : out std_logic_vector( 3 downto 0 )
9 | );
10 | end entity;
11 |
12 | architecture behavioral of buffer4 is
13 | begin
14 | process(buff4_en, datain)
15 | begin
16 | if(buff4_en = '1') then
17 | dataout <= datain;
18 | else
19 | dataout <= (others => 'Z');
20 | end if;
21 | end process;
22 | end behavioral;
Program Counter Code:
1 | library ieee;
3 | use ieee.std_logic_unsigned.all;
4 |
5 | entity pc is
6 | port(
7 | pc_ld, pc_en, pc_clk, pc_rst : in std_logic;
8 | pc_datain : in std_logic_vector(3 downto 0);
9 | pc_dataout : out std_logic_vector(3 downto 0)
10 | );
11 | end entity;
12 |
13 | architecture behave of pc is
14 | signal count : std_logic_vector(3 downto 0) := "0001";
15 | signal temp : integer;
16 | begin
17 | process(pc_clk, pc_rst)
18 | begin
19 | if(pc_rst = '1') then
20 | count <= (others => '0');
21 | elsif(pc_clk'event and pc_clk = '1') then
22 | if(pc_ld = '1') then
23 | count <= pc_datain;
24 | elsif(pc_en = '1') then
25 | count <= count;
26 | temp <= conv_integer(count);
27 | if(temp = 16) then
28 | count <= (others => '0');
29 | end if;
30 | count <= count + 1;
31 | end if;
32 | end if;
33 | end process;
34 | pc_dataout <= count;
35 | end behave;
Test Code:
1 | library ieee;
3 |
4 | entity test is
5 | end entity;
6 |
7 | architecture behave of test is
8 |
9 | component mar
10 | port(
11 | mar_clk, mar_clr, mar_en : in std_logic;
12 | mar_datain : in std_logic_vector( 3 downto 0 );
13 | mar_dataout : out std_logic_vector( 3 downto 0 )
14 | );
15 | end component;
16 |
17 | component pc
18 | port(
19 | pc_ld, pc_en, pc_clk, pc_rst : in std_logic;
20 | pc_datain : in std_logic_vector(3 downto 0);
21 | pc_dataout : out std_logic_vector(3 downto 0)
22 | );
23 | end component;
24 |
25 | component buffer4
26 | port(
27 | buff4_en : in std_logic;
28 | datain : in std_logic_vector( 3 downto 0 );
29 | dataout : out std_logic_vector( 3 downto 0 )
30 | );
31 | end component;
32 |
33 | signal databus : std_logic_vector(7 downto 0);
34 | signal addressbus : std_logic_vector(3 downto 0);
35 |
36 | signal gclk : std_logic;
37 | signal mar_clr, mar_en : std_logic;
38 | signal pc_ld, pc_en, pc_rst : std_logic;
39 |
40 | signal buff4_en : std_logic;
41 | signal dataout : std_logic_vector(3 downto 0);
42 |
43 | signal mar_datain, mar_dataout : std_logic_vector(3 downto 0);
44 | signal pc_dataout : std_logic_vector(3 downto 0);
45 |
46 | begin
47 | U1 : pc port map(pc_ld, pc_en, gclk, pc_rst, databus(3 downto 0), pc_dataout);
48 | U2 : buffer4 port map(buff4_en, pc_dataout, databus(3 downto 0));
49 | U3 : mar port map(gclk, mar_clr, mar_en, databus(3 downto 0), addressbus);
50 |
51 | stim_process : process
52 | begin
53 | gclk <= '0';
54 | wait for 10 ns;
55 | pc_ld <= '0';
56 | pc_en <= '1';
57 | pc_rst <= '0';
58 | buff4_en <= '1';
59 | mar_clr <= '0';
60 | mar_en <= '0';
61 | gclk <= '1';
62 | wait for 10 ns;
63 |
64 | gclk <= '0';
65 | wait for 10 ns;
66 |
67 | assert false report "Reached end of test. Start GTKWave";
68 | wait;
69 | end process;
70 | end behave;
I have attached the simulation of the test.vhdl. The Memory Address
Registers takes the input and doesn't output it on the address bus. How
can I make the Memory Address Register output the data on the address
bus?
