Forum: FPGA, VHDL & Verilog Converting binary number to seven-segment-display
von Eric J. (coderic)
My goal is to convert a binary input number to a std_logic_vector
signaling which segments to activate/deactivate on a
seven-segment-display.
'segments' is basically a vector, with each bit representing a segment a
through g, with the display being enumerated clockwise from the top (a)
to the upper left (f). The middle segment is g.
When I run this, I get an error at each if line, telling me that the
'then's are wrong and that I should properly use a 'generate' - which is
not really what I am trying to do.
Can someone tell me how to fix this?
library ieee;
use ieee.std_logic_1164.all;
entity BCDDecoder is
port (
    digit : in std_logic_vector(3 downto 0);
    segments : out std_logic_vector(6 downto 0)
end BCDDecoder;
architecture rtl of BCDDecoder is
begin
if digit = "0000" then
    segments <= "1111110";
end if;
if digit = "0001" then
    segments <= "0110000";
end if;
if digit = "0010" then
    segments <= "1101101";
end if;
if digit = "0011" then
    segments <= "1111001";
30
end if;
31
32
if digit = "0100" then
33
    segments <= "0110011";
34
end if;
35
36
if digit = "0101" then
37
    segments <= "1011011";
38
end if;
39
40
if digit = "0110" then
41
    segments <= "0011111";
42
end if;
43
44
if digit = "0111" then
45
    segments <= "1110000";
46
end if;
47
48
if digit = "1000" then
49
    segments <= "1111111";
50
end if;
51
52
if digit = "1001" then
53
    segments <= "1110011";
54
end if;
55
end architecture rtl;
You can use if-then only inside a process. As a concurrent statement use
when-else or with-select:
https://insights.sigasi.com/tech/signal-assignments-vhdl-withselect-whenelse-and-case/
