Forum: FPGA, VHDL & Verilog Clock domain crossing
von Stefania M. (val_1010)
Hi! I have a doubt regarding clock domain crossing from a fast clock to
a slower one. Is it possible to use the two flip flops scheme? If yes,
would my code be okay?
sinc_in indicates if data in is valid, sinc_out if data out is valid in
the secod clock domain and clk1 is faster than clk2, so clk2 is the new
domain.
entity clock_sync is
port(
     clk1 : in std_logic;
     clk2 : in std_logic;
     sync_in : in std_logic;
     Data_in : in std_logic_vector(7 downto 0);
     data_out : out std_logic_vector(7 downto 0);
     sync_out : out std_logic
architecture behavioral of clock_sync is
constant in: std_logic_vector (7 downto0):=(others=>0);
type ff is array(0 to 1) of std_logic_vector(7 downto 0);
signal sig_reg : ff:=(others=>in);
signal i: integer:=0;
begin
  process(Clock2)
    begin
      if rising_edge(Clock2) and sync_in=1 then
        if i < 2 then
         i<=i+1;
         sig_reg(i)<= Data_in;
         sync_out<=0;
        else data_out<=sig_reg(i-1);
             sync_out<=1;
30
        end if;
31
      end if;
32
   end process;
33
end behavioral;
Thank you!!
: Edited by User
von -gb- (Guest)
Stefania M. wrote:
> if i < 2 then
>          i<=i+1;
Uiuiuiuiui, looks like a programming language ...
> signal buffer : ff:=(others=>in);
Why not:
signal buffer: std_logic_vector(15 downto 0):=(others => '0');
if Data_in is set for only one cycle of the fast clock, you can miss it
with the slow clock. So no, this will not work reliable.
But Lothar has written a component which takes a short puls and converts
it to an full clock cycle of another clock:
http://www.lothar-miller.de/s9y/archives/19-Kurzer-Spike-in-Puls-umgewandelt.html
Vivado from xilinx also has CDC XPMs which you could use. They are in
the language templates XPM_CDC.
von Duke Scarring (Guest)
-gb- wrote:
> buffer
Naming a signal 'buffer' is not the best idea, because it is a reserved
word in VHDL:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx11/ite_r_vhdl_reserved_words.htm
Duke
> domain.
Can you sketch this down in a timing diagram?
Only when the data rate on the fast clock domain is slower than the clk
on the slow clock domain.
> If yes, would my code be okay?
Forget this, because sync_in is asynchronus to clk2 and then the usual
happens: sync_in acts as an enable for the counter i which consists ofd
several flipflops.
And so sync_in is routet to each of the flipflops. Finally you will get
this:
http://www.lothar-miller.de/s9y/archives/64-State-Machine-mit-asynchronem-Eingang.html
Or, lets simply say the counter i is a FSM (as each counter is).
And never ever(!!) use an async input in a FSM
von -gb- (Guest)
> word in VHDL:
You are right, sorry ...
von Christophz (Guest)
Yes. But as Lothar pointed out, Sync_in is asynchronous to Clk2 so you
have to apply the two flip flops to this signal.
And you have to validate that Sync_in is stable for enough time with
regard to the slow clock. Either this is true due to your application or
you make it true with a pulse-stretcher.
No.
You applied the two flip flops to the parallel data. This can randomly
fail due to latency differences in the separate parallel paths.
Have a look at the paper "Fourteen ways to fool your synchronizer", you
hit number 12 on page 6 :-)
Example to do CDR in this case:
You synchronize Sync_in and then use this (let's call it Sync_clk2)
signal to enable your single output register. Add another flip flop to
Sync_clk2 to generate Sync_out so it will be high at the same time the
data is valid at the register output.
von Jan M. (jamo)
Hey,
the general approach is:
- create a 1-bit(!) toggle event in the fast clock domain (*_event) when
your data changes
  - make sure that it is stable long enough so that in can be captured
safely in the slow clock domain
- bring that into the slow clock domain with at least two FFs (*_meta
and *_rt)
- create another delay FF of *_rt (*_rt_z) and compare that with xor or
neq
  - if this comparison is true capture your bus from fast into slow
clock domain
- you need to tell the synthesis tool your (known good) cdc paths (for
Xilinx Vivado I always use set_max_delay constraints, better then just a
tig/set_false_path)
- also use async_reg constraint on your *_meta/*_rt FF pairs
- for Altera/Intel they must be similiar constraints available
Good luck!
BR,
Jan :)
: Edited by User
von SparkyT (Guest)
does this technique for domain crossing from slow-to-fast apply when
both CLK signals come from the same PLL and are in phase?
I have been using the 2 FF synchronization from fast-to-slow, bet never
the other way around.
Thanks
T
