Forum: µC & Digital Electronics The use of the diode in this circuit
von Alex (Guest)
So basically this is a circuit with 2 diodes and it represents a NOT
Circuit.
But I don't understand the use of the Diode 2 (D2) here . Even without
it the circuit represents still a NOT Circuit  .
: Moved by Moderator
von MaWin (Guest)
Without it, if T2 urns on and directs the current to T4, it may not pull
down the base , and in effect the voltage between its emitter and base,
of T3 low enough to turn it off.
UBE(T2)+UBE(T4) must be < UCE(T4)+UBE(T4) and may not be the case.
But UBE(T2)+UBE(T4) < UCE(T4)+Uf(D2)+UBE(T4) cetainly holds.
von Alex (Guest)
I'm not sure that I understand what you said . I'm kinda lost with the
UBE UCE and UF symbols because I'm not familiar with them.
Have a look at the screenshots that I made with/without Diode and tell
me what I'm doing wrong .
Plus I'd like to know what's UBE UCE and UF with the use of the voltage
shown in my screenshots . That will be great to understand their
meanings.
von Alex (Guest)
As you can see in the screenshots . They both lead me to the same
result. That's why I got confused
von MaWin (Guest)
> result.
Why do you write 0V an the first output an 0.2V on the second ?
Why is Uf just 0.2V ?
Use realistic UBE, UCE and Uf values, for instance 0.7 0.2 and 0.7V or
from a transistor data sheet or use LTSpice.
The input transistor also has wrong 0.7V on base. It mainly works like 2
diodes, either directing the current thru the 4k7 resistor into the base
of the T2 or into te input.
I made a mistake in the formuals
UBE(T2)+UBE(T4) must be < UCE(T4)+UBE(T3) and this will not be the case.
But UBE(T2)+UBE(T4) < UCE(T4)+Uf(D2)+UBE(T3) cetainly holds
von foobar (Guest)
> They both lead me to the same result.
Except that in the right diagramm T3 and T4 are both on and you have a
short.  In the left, the 0.2V is not enough for the diode to conduct[1]
and no current flows through T3.
[1] especially as the output is also 0.2V and not 0 (the
collector-emitter voltage of T4) and hence the voltage across the diode
is ~0V.
von Alex (Guest)
So the diode D2 function would be on this case : Preventing a short
circuit ?
von MaWin (Guest)
> circuit ?
Yes, or in other words: allow the output circuit to work as intended.
