Forum: FPGA, VHDL & Verilog VHDL: Synchronizing an asynchronous interface without a clock
von Alex K. (ak55)
I am trying to implement a custom bridge between a clocked synchronous
interface and an asynchronous interface which is not clocked. I am
having difficuties in synchronizing the asnychronous interface. I want
to synchronize it to avoid timing issues in Quartus.
The signals like ebi_cs_n, ebi_bs1_n are misinterpreted as clocks by the
tool when left asynchronous. I want to avoid that.
Please find the code in attachments.
How can I get a synchronous behavior of the synchronous interface. Or is
there a better way to kepe the asynchronous interface without running
into metastability  issues.
P.S. Unfortunately the asynchrnonous interface comes without a clock.
And that is why I want to turn into a clean code having a synchronous
behavior
: Edited by User
von Klakx (Guest)
if your EBI runs at ..50 MHz or lower then a reliable approach can be
achieved by using a high oversampling clock, like 200 MHz.
You have written them in a way, they must be "clocks" to a latch.
Indeed you should avoid latches unless you want them. And if you want
them e.g. for the storing signal s_TSREV then you must accept that the
toolchain invokes some kind of clock for those signals.
The other way (as already said) is to oversample and synchronize the
control signals cs, we, bs... and work with the synchronized signals
further on (edge detection for storing/latching the bus value...).
BTW: where did you find this strange kind of code?
   process(avln_clk, avln_reset)
       variable sync_rst   : std_logic;
   begin
       if falling_edge(avln_clk) then
           sync_rst    := not avln_reset;
       end if;
       if rising_edge(avln_clk) then
           nReset    <= sync_rst;
       end if;
   end process;
This is a very uncommon way to tighten up the timing requirements to the
design. Or with other words: do not use both edges of a clock in 1
design. Additionally the avln_reset ist not needed in the sensitivity
list, because the result of the process only depends on the avln_clk.
