1 | --------------------------------------------------------------------------------------------------------------------------------------------------- ----------------------
2 |
3 |
4 | for row_i in 0 to image_height - 1 loop
5 |
6 | -- Create a new row type in dynamic memory
7 | row := new row_type(0 to image_width - 1);
8 |
9 | for col_i in 0 to image_width - 1 loop
10 | (=> THIS line) read(bmp_file, char);
11 |
12 | ---------------------------------------------------------------------------
13 | library ieee;
14 | use ieee.std_logic_1164.all;
15 | use ieee.numeric_std.all;
16 |
17 | use std.textio.all;
18 | use std.env.finish;
19 |
20 | entity read_bmp_tb is
21 | end read_bmp_tb;
22 |
23 | architecture sim of read_bmp_tb is
24 |
25 | type header_type is array (0 to 117) of character;
26 |
27 | type pixel_type is record
28 | red : std_logic_vector(7 downto 0);
29 | green : std_logic_vector(7 downto 0);
30 | blue : std_logic_vector(7 downto 0);
31 | end record;
32 |
33 | type row_type is array (integer range <>) of pixel_type;
34 | type row_pointer is access row_type;
35 | type image_type is array (integer range <>) of row_pointer;
36 | type image_pointer is access image_type;
37 |
38 | -- DUT signals
39 | signal r_in : std_logic_vector(7 downto 0);
40 | signal g_in : std_logic_vector(7 downto 0);
41 | signal b_in : std_logic_vector(7 downto 0);
42 |
43 | signal r_out : std_logic_vector(7 downto 0);
44 | signal g_out : std_logic_vector(7 downto 0);
45 | signal b_out : std_logic_vector(7 downto 0);
46 |
47 | begin
48 |
49 | DUT :entity work.grayscale(rtl)
50 | port map (
51 | r_in => r_in,
52 | g_in => g_in,
53 | b_in => b_in,
54 |
55 | r_out => r_out,
56 | g_out => g_out,
57 | b_out => b_out
58 | );
59 |
60 | process
61 | type char_file is file of character;
62 | file bmp_file : char_file open read_mode is "Before.bmp";
63 | file out_file : char_file open write_mode is "After.bmp";
64 | variable header : header_type;
65 | variable image_width : integer;
66 | variable image_height : integer;
67 | variable row : row_pointer;
68 | variable image : image_pointer;
69 | variable padding : integer;
70 | variable char : character;
71 | begin
72 |
73 | -- Read entire header
74 | for i in header_type'range loop
75 | read(bmp_file, header(i));
76 | end loop;
77 |
78 | image_width := 1666;
79 |
80 | image_height := 1267;
81 |
82 | -- Number of bytes needed to pad each row to 32 bits
83 | padding := (4 - image_width*3 mod 4) mod 4;
84 | report "padding: " & integer'image(padding);
85 |
86 | -- Create a new image type in dynamic memory
87 | image := new image_type(0 to image_height - 1);
88 |
89 | for row_i in 0 to image_height - 1 loop
90 |
91 | -- Create a new row type in dynamic memory
92 | row := new row_type(0 to image_width - 1);
93 |
94 | for col_i in 0 to image_width - 1 loop
95 | -------------------------------------------------------------------------------------------------------------------------------------------------------------
96 | -- Read blue pixel
97 | --------------------------------------------- --------------------------------------------- ---------------------------------------------
98 | read(bmp_file, char);//Error starts from here
99 | row(col_i).blue :=
100 | std_logic_vector(to_unsigned(character'pos(char), 8));
101 |
102 | -- Read green pixel
103 | read(bmp_file, char);
104 | row(col_i).green :=
105 | std_logic_vector(to_unsigned(character'pos(char), 8));
106 |
107 | -- Read red pixel
108 | read(bmp_file, char);
109 | row(col_i).red :=
110 | std_logic_vector(to_unsigned(character'pos(char), 8));
111 |
112 | end loop;
113 |
114 | -- Read and discard padding
115 | for i in 1 to padding loop
116 | read(bmp_file, char);
117 | end loop;
118 |
119 | -- Assign the row pointer to the image vector of rows
120 | image(row_i) := row;
121 |
122 | end loop;
123 |
124 | -- DUT test
125 | for row_i in 0 to image_height - 1 loop
126 | row := image(row_i);
127 |
128 | for col_i in 0 to image_width - 1 loop
129 |
130 | r_in <= row(col_i).red;
131 | g_in <= row(col_i).green;
132 | b_in <= row(col_i).blue;
133 | wait for 10 ns;
134 |
135 | row(col_i).red := r_out;
136 | row(col_i).green := g_out;
137 | row(col_i).blue := b_out;
138 |
139 | end loop;
140 | end loop;
141 |
142 | -- Write header to output file
143 | for i in header_type'range loop
144 | write(out_file, header(i));
145 | end loop;
146 |
147 | for row_i in 0 to image_height - 1 loop
148 | row := image(row_i);
149 |
150 | for col_i in 0 to image_width - 1 loop
151 |
152 | -- Write blue pixel
153 | write(out_file,
154 | character'val(to_integer(unsigned(row(col_i).blue))));
155 |
156 | -- Write green pixel
157 | write(out_file,
158 | character'val(to_integer(unsigned(row(col_i).green))));
159 |
160 | -- Write red pixel
161 | write(out_file,
162 | character'val(to_integer(unsigned(row(col_i).red))));
163 |
164 | end loop;
165 |
166 | deallocate(row);
167 |
168 | -- Write padding
169 | for i in 1 to padding loop
170 | write(out_file, character'val(0));
171 | end loop;
172 |
173 | end loop;
174 |
175 | deallocate(image);
176 |
177 | file_close(bmp_file);
178 | file_close(out_file);
179 |
180 | report "Simulation done. Check ""out.bmp"" image.";
181 | finish;
182 | end process;
183 |
184 | end architecture;
185 |
186 | ----------------------------------------------------------------------------------------------------------------------------------------
