Forum: FPGA, VHDL & Verilog How to use USB port of FPGA to access webcam
von Lakshita J. (lakshita)
Hello all,
I am working on a project related to image processing and I want to
capture the photo using a USB webCAM.
Can anyone please tell me How to interface Logitech webcam through USB
port of any FPGA board(i.e. Zybo, Zedboard, Basys3)?
von Alexx (Guest)
Is this your homework? You need to use the driver to acess the webcam.
Use embedded linux on the ZYNQ platform. I worked with xillybus once for
a project at university, it worked for us. You need a linux driver for
the webcam and if you need it in the programmable logic xillybus helps
you to stream it there....
Lakshita J. wrote:
> webcam through USB port of any FPGA board(i.e. ... Basys3)?
Read, how the both USB connectors J2 and J4 of the Basys3 board are
connected to the FPGA. You will find out, that you cannot implement a
USB host to get data from the connectors to the FPGA.
See there:
https://reference.digilentinc.com/_media/reference/programmable-logic/basys-3/basys3_rm.pdf
> Zybo, Zedboard,
Do the same here.
Zybo: the USB Micro AB connector J9 offers USB2.0 OTG functionality.
https://reference.digilentinc.com/reference/programmable-logic/zybo/reference-manual
Zedboard: see Chapter 2.3.1 there the manual
http://www.zedboard.org/sites/default/files/documentations/ZedBoard_HW_UG_v2_2.pdf
For connecting a USB device to a FPGA being the host, you 1. must
implement the USB host hardware connection and 2. you must implement the
host driver to connect to the USB device and retrieve data from the
connected USB device. None of those both tasks are for beginners.
So use a board able to run a linux OS and its drivers to connect to the
webcam. Then capture the picture to RAM and then start your own image
processing. This alone will be demanding enough.
: Edited by Moderator
Thank u all for the valuable information. Can you provide any useful
links related to this topic of using USB Webcam?
: Edited by User
von Christophz (Guest)
Most USB webcams implement the standard "USB video class" therefor you
should follow the official documentation for this devices:
https://www.usb.org/document-library/video-class-v15-document-set
And the USB standard as the base:
https://www.usb.org/document-library/usb-32-specification-released-september-22-2017-and-ecns
As said before, we would suggest you to use a simpler interface to
connect a camera to an FPGA. USB is complex from a developers
perspective.
