Forum: FPGA, VHDL & Verilog is it possible for bcd to ascii module?
von John B. (Company: USF) (noitabrutsam)
if so, can you help me where to start?
von alex (Guest)
1. Ensure that BCD is in range of borders 0...99
2. Per Byte: Byte to Hi/Lo nibble ( shift by 4 and with 0x0F for hi, and
with 0x0F for lo nibble)
3. Per Nibble: ASCII = nibblevalue + 0x30
See also wiki
ASCII      char 0x30 = '0'
von Luke Wren (Guest)
Something like
module bcd2ascii #(
    parameter N_DIGITS = ...
    input wire [4*N_DIGITS-1:0] bcd_in,
    output reg [8*N_DIGITS-1:0] ascii_out
integer i;
always @ (*) begin
    for (i = 0; i < N_DIGITS; i = i + 1) begin
        ascii_out[i * 8 +: 8] = 8'h30 + bcd_in[4 * i +: 4];
    end
end
endmodule
Could be what you need. It would require some effort on your part to
adapt this to your needs and make sure that it works. You didn't mention
language, so I assumed Verilog.
von S. R. (svenska)
Yes, it is possible.
a) convert 4 bit BCD to binary (easy: use a table)
b) convert binary to ASCII digit (easy: add 0x30)
Repeat for every digit.
von ronit (Guest)
what does this statement mean =(" parameter N_DIGITS = ...")
Can you please explain, it's a bit of an emergency
What about Google like "verilog parameter"?
Within seconds you find the explanation:
http://www.asic-world.com/verilog/para_modules1.html
von Harry (Guest)
can anyone help me to wrie a multichannnel UART verilog code?
Start a new thread for an new question!
Provide something with a particular problem. No one will do your entire
homework.
Define more precisely what you mean with "multichannel UART".
