Forum: µC & Digital Electronics 10k Poti for a DAC and Arduino?
von Fadi Safadi (Guest)
Hello everyone.
i am designing an adjustable power supply and in this power supply i am
using an arduino with a built in ADC 10 Bits to control a DAC MAX5217 16
BITS. The DAC output will be driving the adjustable pin of a LDO linear
regulator.
The thing is if i am understanding this correctly. i don't wanna control
this through my PC, i wanna control the output voltage of the DAC with
my hand.
So the question is, i think i can use rotary encoders or 10k Poti right?
which POti should i use and where do you connect it? to the arduino or
where exactly. The picture is not really clear!
Maybe its a newbie question but this is how we learn! i appreciate every
answer.
Best regards,
Fabi
: Moved by Moderator
von Harlekin (Guest)
Yes. Maybe, you like to implement both solutions. That way you learn the
advantages and disadvantages of them. I think encoders are a bit easier
to start with.
It is a good idea to organise the schematic of your arduino and the data
sheet of the microcontroller, which is placed on the arduino.
