Forum: µC & Digital Electronics Suggestion on controller selection
von Aravind M. (raghav2984)
Hi All,
I'm looking for a controller with wifi connectivity. The controller
needs to interact with camera and touch screen input. It needs to have
battery backup and few I/O to operate any 5V supply device.
NOTE: I'm completely new to this field. Looking forward for a good
starting point.
Thanks everyone in advance.
Regards,
Raghav
von matzetronics (Guest)
It sounds to me as if you're looking for a smartphone with an USB
switching device? There's a camera, a touschscreen and an USB Port
already there. All you'd need is a custom App and a USB Extender with a
few digital I/Os.
Correct me if this isn't the easiest way to obtain a device.
Oh, btw, USB switching devices can be either selfmade with e.g. the
V-USB software for AVR:
https://www.obdev.at/products/vusb/index-en.html
or it could be a commercial device like the IO Warrior:
https://www.codemercs.com/en/io-warrior
Hi Matzetronics,
Thank you for the reply. I hope that could be nice. But as I mentioned
I'm really new to this area (I work on CNC controllers). This project is
for a hobby and I may need to develop it later. I may need to use a
Bar-code scanner as well. I'm not sure of how feasible it would be with
a smart phone with respect to improvements. Also I need to think of
programming aspect. Kindly provide your thoughts on the same.
Regards,
Raghav
Aravind M. wrote:
> I may need to use a
This is also a task that a smartphone could handle. Either way, most of
the hardware you mentioned is already built into these devices and they
come with Bluetooth connectivity as well which could be useful for
external devices like an external scanner or ohter input.
Its just a thought and might be easier than a controller like e.g. the
STM32F429 which has TFT driving, USB and e.g. SD Card ports.
If you think about writing your own software from scratch, have a look
at the Discovery Boards from STM, like the above mentioned F429 or the
latest F7 series.
http://www.st.com/en/evaluation-tools/stm32-mcu-discovery-kits.html?querycriteria=productId=LN1848
von Aravind (Guest)
Thank you so much for the suggestion. I will have a look over the boards
this weekend. So they mention Aurdino uno connections. It means that it
has a aurdino board to support i/o connections? If bar code reader is
wired, then can we connect in stm f7 boards? And how about the camera
connections? Sorry for too many silly questions. Once again thanks a
lot.
