Forum: FPGA, VHDL & Verilog verilog Voltage Control Oscillator
von Rock B. (rocko445)
Hello, from the  theory in the attached photo i have implemented  the
formula  in the VERILOG code bellow, the syntax check was fine but when
i tried in XILINX  to force values  the simulation gives me an empty
screen and says:
# run 1.00us
INFO: Simulator is stopped.
where did i go wrong in entering the coefficients?
Thanks
module vvco(fo,vctl,kv);
input fo,vctl,kv;
reg vco_b=1'b0;
reg fo_b=3'b0;
reg vctl_b=3'b0;
reg kv_b=3'b0;
always #((1/fo_b-vctl_b*kv_b/fo_b^2)/2) vco_b<=~vco_b;
endmodule
: Edited by User
von Duke Scarring (Guest)
I never worked with forced values to simulate a design.
I usually write testbench to check my code and apply different stimuli.
Duke
von Varun (Guest)
I am also facing the same problem.
von Klakx (Guest)
maybe it is not supported by your simulator, as noted in the last
paragraph of your document
