Forum: FPGA, VHDL & Verilog Verilog Simple SPI Code?
von Ferhat Y. (Company: LEDMER ELEKTRONİK) (mucit23)
Hi Friends
I am trying to make a simple spi module with verilog. After I get the
Enable signal, I want to send the 8 bit data in series.
I've never worked with a verilog before.
I wrote a simple code but I do not know how to generate the clock
signal.
this is my Code;
`include "cypress.v"
//`#end` -- edit above this line, do not edit this line
// Generated on 03/31/2017 at 15:12
// Component: ParalelToSerial
module ParalelToSerial (
  output  Busy,
  output  Clkout,
  output  Dout,
  input   Clkin,
  input  [7:0] Data,
  input   En
//`#start body` -- edit after this line, do not edit this line
    reg busy;
    reg dout;
    reg clkout;
    reg [3:0]cnt_spi;
    reg clk_count;
    assign Busy = busy;
    assign Dout = dout;
    assign Clkout = clkout;
    always @ (negedge Clkin)
    begin
       if(En == 1'b1 && busy == 1'b0)
       begin
         clkout=1'b0;
30
         dout=Data[cnt_spi];
31
         cnt_spi = cnt_spi + 1;
32
       end
33
34
       if(cnt_spi == 8)
35
         busy=1'b0;
36
       begin
37
38
       end
39
    end
40
41
42
endmodule
I will be glad if you help me. I'm just looking for a very simple
example of spi.
: Edited by Moderator
So, why not starting with a flashing LED?
So you want to do an SPI master. For me the SS is missing there...
> I wrote a simple code but I do not know how to generate the clock signal.
You must
1. you must generate a scaled down SCLK "clock" signal out of the FPGA
clock (which is usually round 50MHz)
2. you must generate a SS slaveselect signal and activate it before
start of transaction
3. you must shift the data bit by bit on the MOSI line according to the
phse of the SCLK
5. you must be aware that the SCLK is a simple output signal and NO
clock(!!!)
4. you must set up a test bench to verify the behaviour of the whole
thing
But if I were you I would start with the LED and simulate it before
going on real hardware. And be aware: the simulator is the HDL debugger!
Hi @Ikmiller
Thank you for the reply.
Before starting this application, I did flashing LED.
I'm testing it in real hardware. it works :)
    always @ (posedge Clkin)  //1Khz Clock İnput
    begin
      if(counter== 500)
      begin
        counter=0;
        clkout = ~clkout;
      end
    end
Now, I'm working on the PSoC devices. PSoCs have microcontroller and
PGA. PGA is programmed with verilog like fpga. I don't need SS in my
application because, I'm driving P10 LED panel, This panels only have
DATAIN and CLOCKIN inputs.
PSoC itself is doing frequency division. I only determine the clock
frequency.
PSoCs are being designed with blocks. (my design in the attachment)
Now I need to write the contents of the Parallel_to_Serial module with
verilog.
I've sent a bit of bits to send
dout=Data[cnt_spi];
I just need to generate the SCLK signal.And a little control. (Busy
signal vs)
Do a simulation on it. Just to learn how a simulation is done. You will
find out, that there is a problem in your design: with a 1kHz clock you
will not get the desired 1Hz flashing...
Run the FPGA on a much higher clock. And from there generate clock
enables for slower timings.
> verilog.
Its just a parallel loaded shift register.
> I've sent a bit of bits to send dout=Data[cnt_spi];  I just need to
When looking at the picture: you already have a clock...
> And a little control. (Busy signal vs)
And it will be a good idea to add a sync signal (in SPI its called SS
slaveselect) to the output.
von Andreas R. (daybyter)
This example is with automatic shiftout.
IIRC, it was not tested yet on real hardware. Only in simulator.
Just found a more simple version. spi_master2.
: Edited by User
von Sharon M. (Company: CETPA Infotech Pvt Ltd) (sm2345110)
Syntax
$dumpfile("filename.vcd")
$dumpvar //dumps all variables in the design.
$dumpvar(1, top) //dumps all the variables in module top and below, but
not modules instantiated in top.
$dumpvar(2, top) //dumps all the variables in module top and 1 level
below.
$dumpvar(n, top) //dumps all the variables in module top and n-1 levels
below.
$dumpvar(0, top) // dumps all the variables in module top and all level
below.
$dumpon // initiates the dump.
$dumpoff // stop dumping
All the best :)
VLSI Training at CETPA
von Gaz (Guest)
In all honesty doing a SPI design is quite tricky.  Usually a state
machine and edge detection is used along with counters (for which bit is
coming in).  This is not a trivial design. Be forewarned.
von Joe F. (easylife)
Don't the PSoCs offer an SPI master module which you could easily use
within your main firmware (written in C)?
von Klammer Johann (Guest)
here's sthg I wrote a while back. never used. don't know if works.
von Mark (Guest)
http://www.cypress.com/training/psoc-video-tutorial-series-how-create-custom-components
I have used recently the SPI Master component build in in Creator. It
works fine for LEDs, just you need to assign MISO and SS to any unused
pins.
von Ananthoji Vineeth Kumar (Guest)
I want spi code with testbench in verilog
OMG. Hard to stay polite... Decided to better keep my mouth shut.
Sorry to say that I only can offer one in VHDL:
http://www.lothar-miller.de/s9y/categories/45-SPI-Master
But after starting thinking it its fairly easy to translate it to
Verilog.
BTW:
Did you read the posts in this thread?
Mark the correct answer with a cross:
[  ] No
von https://youtu.be/3KO3e4I3_24 (Guest)
I provide these  all the time! These are typically amazing good quality
lace wigs,bob wigs https://youtu.be/3KO3e4I3_24. I obtained
contemplating I get lots of compliments on them every day from good
friends, academics, even strangers! :)
