Forum: Analog Circuits LED-strip dimming without PWM
von F. L. (filmwerkstatt)
Hello everyone!
I'm not an engineer but i want to do something special - or so it seems.
I want to power 2m of this LED strip (12V, 36W, 3A for 2m (120 LEDs)):
http://store.yujiintl.com/products/high-cri-led-ribbon-60-led-m-95-98-cri?variant=808351017
with that Lithium-ion battery (Sony BP-U60, 14.4V, 3.9Ah):
http://www.sony.co.uk/pro/product/broadcast-products-camcorders-batteries-power-supplies/bp-u60/specifications/
I want to dim it from 0% to 100% (if possible) without PWM - i will use
it for filming purposes and flickering is an absolute no-go. Sometimes i
do slow-motion shoots with up to 2000fps - this might be extreme, but
flicker-free till around 400fps would be nice. So PWM is out...
I tested it with my lab power supply: Around 7V its around 5% (and it
doesn't flicker at normal framerates).
Additionally, i want to make sure i dont fully drain my batteries.
And, it's crucial that the brightness stays always the same - if the
batteries can't deliver what i want it should be turned off or at least
flash some red LED.
As i see it, i need:
1. Adjustable voltage regulator from ±14,4V to 7V - 12V, 3+A
2. Some relais that is triggered when voltage in the battery drops below
the adjusted voltage
3. Heat absorber of some sort
Questions:
Where do i find a voltage regulator with my specifications? Do I have to
make my own? If so, does someone know a schematic which withstands 3+
amps?
What is that 'relais' part called? Due it beeing dependent on the
adjusted voltage, does a combo part exist somewhere?
Every though is much appreciated. Thanks!
: Moved by Moderator
von Joe F. (easylife)
Depending on the LED driver you're using, an extremely high PWM
frequency (10-20 KHz) might be an option.
Dimming white LEDs by reducing voltage/current in general does not work
well.
Color temperature will change drastically or even shift to a color which
could not in a bit be called "white" which makes it completely unusable
for photographic lighting.
If reducing brightness in discrete steps is acceptable, I'd suggest to
find a way to simply switch off every 3rd, 2nd, 2 of 3... LED and keep
the remaining LEDs at full brightness.
Also applying neutral density foil is a good way to reduce brightness
without changing color temperature.
Or setting up a mechanical "shutter" (e.g. black wrap) in front of the
lamp might work as well.
von Georg M. (g_m)
http://www.conrad.ch/ce/de/content/filiale_dietlikon/
von russia (Guest)
thank you all for your thoughts!
> well.
Sadly i don't have a color meter, and this would indeed destroy the
purpose of LEDs with a CRI > 98. But from bare eye i don't see a color
shift at all, and i'm kind of trained to detect color shifts in light
sources. But i might be wrong of course.
this would be the best option, but i can't imagine the nigthmare of
wiring 120 LEDs this way. And, if it should really work as a
photographic light, it has to have the versitality of dimming in smaller
steps.
Of course, that would work, but I want to save energy, too. The battery
lasts only around 1.3h @ 12V till completly empty and it would be nice
if it would last longer if dimmed down.
Well, i build a 'practical' - light source that is in frame. Even though
i love black wrap, this isn't the place for it.
russia wrote:
> Try this:
http://www.ebay.de/itm/High-Power-Buck-Converter-DC-4-32V-zu-1-2-32V-15A-Adjustable-Step-Down-Converter-/361867758044?hash=item5440ffc9dc:g:MXcAAOSwEzxYdhgH
this look very promising! If there's no other option than go with just a
lot of hertz, 150KHz should be enough.
what about cutting power off if the voltage drops?
: Edited by User
von russia (Guest)
russia wrote:
> https://www.youtube.com/watch?v=jLia59KfkSw&t=406s
oh my god, the internet is fantastic.
this is perfect and exactly what i need. thanks a bunch!!
