Forum: FPGA, VHDL & Verilog Creating Multi Files
von Christin K. (christinkimeri)
Im exporting the data to a  file using print but now I need to solve
this system for different values of my parameters and i dont want to
create different files manually. Does anyone knows how can I create
different files to store the different solutions i get for the different
values of my parameters?
Sorry for my english and thanks!
From WHERE?
> Does anyone knows how can I create different files
With WHAT?
What language do you use?
: Edited by Moderator
I am using VHDL language.
Different data should be write into  different files by creating
manually...
Below is the equivalent C code. I am not able convert it to VHDL..
FILE *files[numfiles];
for (int i = 0; i < numfiles; i++)
    char filename[20];
    sprintf(filename, "results%d.dat", i);
    files[i] = fopen(filename, "w");
von Duke Scarring (Guest)
Here is a starting point:
entity multiple_files_tb is
end entity multiple_files_tb;
library std;
use std.textio.all;
architecture testbench of multiple_files_tb is
    constant filename : string := "results";
begin
    main: process
        file        outfile : text;
        variable    status  : file_open_status;
        variable    l       : line;
    begin
        for index in 0 to 20000 loop
            file_open( status,  outfile, filename & integer'image( index) & ".dat", write_mode);
            if status = open_ok then
                write( l, "this is file nr. " & integer'image( index));
                writeline( outfile, l);
            else
                report "error opening file " & integer'image( index);
            end if;
            file_close( outfile);
        end loop;
        wait; -- forever
    end process;
30
end architecture testbench;
Text and file processing is no fun in VHDL. I would write everything
with a tag in a single file.
After that you could any better tool for processing like python, matlab,
c, you-name-it.
Duke
Thanks a lot Duke Scarring.
       Requirement is in VHDL.Can you suggest where can i get materials
on File system in VHDL.
Christin K. wrote:
> Can you suggest where can i get materials on File system in VHDL.
Look there somewhere around page 500:
http://xilinx.eetrend.com/files-eetrend-xilinx/forum/201404/7000-11806-the_designers_guide_to_vhdlpeter_j.ashenden.pdf
And there was stefanvhdl.org ...
As a pity its offline now, but with wayback you ca look a captured
version of the page:
https://web.archive.org/web/20160914062538/http://stefanvhdl.com/vhdl/html/index.html
Thank you lkmiller..
