Forum: FPGA, VHDL & Verilog Simple clock counter says it cant be synthesized (vhdl)
Author: Crim (Guest)
Hello there, when trying to synthesize that code i get the following
error from ise
 ERROR:Xst:827 -  line 18: Signal count cannot be synthesized, bad
synchronous description. The description style you are using to describe
a synchronous element (register, memory, etc.) is not supported in the
current software release.
do you have any idea why that happens ?
here is the code
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity alt_clock is
  generic (time1 : integer:=3);
  port(clk,rst: in std_logic;
       done: out std_logic);
end alt_clock;
architecture aarch of alt_clock is
begin
P0:process(clk) -- this is the line 18
  variable count :integer range time1 downto 0;
  begin
    if clk'event and clk='1' and rst='1' then
      count:=0;
      done<='0';
    elsif clk'event and clk='1' and rst='0' then
      if count<time1 then
        count:=count+1;
        done<='0';
      elsif count=time1 then
        done<='1';
        count:=0;
      else null;
      end if;
    end if;
end process;
end aarch;
Author: Donni Donis (donnidonis)
are you sure you want to have a syncron reset? If so, make one clk'event
and in there a if rst=x then...
Also every signal which you read in a process should be in the process
sensitivity list.
And why declare an integer from three to zero? I count numbers ascending
: Edited by User
> error from ise
Have a look in the Synthesizers User Guide. In it you find how you must
write your VHDL code to get  your desired components.
If you don't find your specific way of description, then the synthesizer
cannot translate it to hardware.
If your case the problem is the "double clock". This way of description
you can find nowhere...
BTW: forget variables fir the first weeks doing VHDL. They usually
behave different than you expect.
: Edited by Moderator
Thanks a lot everyone :)
  • [vhdl]VHDL code[/vhdl]
