Forum: FPGA, VHDL & Verilog Error in my program
von ayr (Guest)
The entity shall implement the following arithmetic functionality:
• Substraction I1 - I2
• Input operand 1 (I1): 12 bit, two’s complement
• Input operand 2 (I2): 8 bit, two’s complement
• Output (O): 12 bit, two’s complement
• Overflow (V) and Carry flag (C) set accordingly
• Valid flag (VALID): indicates if the computed solution is valid or not
So what I have done?
Here is it:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
entity arithmetic is
port( I1 :in std_logic_vector(12-1 downto 0); -- Operand 1
I2 :in std_logic_vector(8-1 downto 0); -- Operand 2
O :out std_logic_vector(12-1 downto 0); -- Output
C :out std_logic; -- Carry Flag
V :out std_logic; -- Overflow Flag
VALID :out std_logic -- Flag to indicate if the solution is valid or not
end arithmetic;
architecture behavior of arithmetic is
begin
process(I1,I2)
begin
if ((unsigned(I1)-unsigned(I2)) > unsigned(I1)) and
((unsigned(I1)-unsigned(I2)) > unsigned(I2)) then
C <= '1';
else
C <= '0';
end if;
if I1(11)='1' and signed(std_logic_vector(unsigned(I1)-unsigned(I2)))>0
then
V <= '1';
else
V <= '0';
end if;
if unsigned(I1) < unsigned(I2) then
VALID <= '0';
else
VALID <= '1';
end if;
O <= std_logic_vector(unsigned(I1)-unsigned(I2));
end process;
end behavior;
There is no syntax mistakes or something like that. Only mistake is
that:
Error for:
comp2,SUB
I1= 100000011110
I2= 01000001
Expected:
O= 011111011101
C= '0', V= '1', VALID= '0'
Received:
O= 011111011101
C= '0', V= '1' and VALID= '1'
If someone could help I would be really thankful.
von ottonormaloser (Guest)
I am times so free:
library IEEE;
end arithmetic;
begin
process(I1,I2)
begin
if ((unsigned(I1)-unsigned(I2)) > unsigned(I1)) and ((unsigned(I1)-unsigned(I2)) > unsigned(I2)) then
C <= '1';
else
C <= '0';
end if;
if I1(11)='1' and signed(std_logic_vector(unsigned(I1)-unsigned(I2)))>0 then
V <= '1';
else
V <= '0';
end if;
VALID <= '0';
else
VALID <= '1';
end if;
end process;
end behavior;
that:
Error for:
comp2,SUB
I1= 100000011110
I2= 01000001
Expected:
O= 011111011101
Received:
O= 011111011101
As an unsigned 100000011110 is 2078 and 01000001 is 64 the result you
get is that whats written in the code:
if 2078 < 65 then
   VALID <= '0';
else
   VALID <= '1';
end if;
So, the remaining question is: what did you want to achieve by that
compare operation?
I would run the subtraction on 13 bit vectors (resize() both vectors to
13 bit and perform the operation on those vectors) and then have a look
how the both MSB behave.
von ayr (Guest)
even when I put signed it's still mistake :/
What do you "put signed"?
What do you expect then and what happens instead?
von ayr (Guest)
To get good valid correct
