Forum: Analog Circuits Comparator with adjustable hysteresis
Author: Harald (Guest)
Hello,
I have to built a current source that controls the current in a coil. I
want to built a ripple regulator that measures the current by a
hall-sensor and switches the half bridge high side on if the current is
too low and switches the half bridge low side on if the current is too
high. Dead time to prevent cross-conduction is in the driver.
I need a high switching frequency for small currents (100kHz @ 20A) and
a low switching frequency for high currents (20kHz @ 200A). I have to
use a current control to have a permanent over current protection.
I want to realize this by adjusting the hysteresis of the comparator.
(see http://www.ti.com/lit/an/snva170b/snva170b.pdf,  Page 2,  Figure 3)
The only schematic I found was this:
https://www.google.com/patents/US5166550
PLEASE has someone a schematic of a comparator with adjustable
hysteresis for me. Best would be a ground referenced voltage input for
the hysteresis adjustment.
THANKS for your help!!!!
Best Regards
Harald
Author: catal (Guest)
The easiest way to accomplish independent setpoints is by using two
comparators and combine their outputs with a SR latch (similar to a
window comparator circuit, SR replaces the AND).
For the example attached, I assumed a sensitivity of 20mV/A and a ripple
of 10%. To fit 20kHz@200A the current rise and fall times are set to
0.8A/µs.
Unfortunately, using the same settings, the frequency at 20A is 200kHz.
But I'm not shure, if it's your intention to allow a ripple of 20% to
keep the freqeuncy as low as 100kHz. Anyhow, if it's necessary to set
the ripple otherwise than by percentage of the maximum value (or to a
fixed value), I would use a microcontroller (D/A-Converter, PWM).
Thanks for your help !!!!
I did it with 2 comparators and a edge triggered RS-FF made of 2 74hc74.
I made the hysteresis adjustable (current mirrors) and proportional to
the current value.
I also added a frequency/voltage converter and increase the hysteresis
if the switching frequency is to high.
Best Regards
Harald
Author: MaWin (Guest)
> hysteresis for me
It's quite easy: Use an NE555, it has a turn-on point of 2/3 VCC and a
turn off point of 1/3 VCC, and amplify your current signal measured by
the hall sensor so that it will reach the switching points at the
appropriate measured current.
You know hot to build an op-amp amplifier with adjustabnle gain and
offset ?
