Forum: FPGA, VHDL & Verilog FPGA vs ASIC - CDC
Author: Fpga Rookie (fpga_rookie)
Hi all,
Is handling CDC issues on FPGA should be (is) any different from
handling CDC issues on ASIC? I.e., Are the same techniques in ASIC apply
in FPGA?
Thanks!
Author: Gustl Buheitel (-gb-)
I don't know how it is done in ASICs but i can't think oft any reason
why there should be any difference.
Author: Sym (Guest)
Basically the same. On some ASIC technologies a special type of
registers is used for CDC flip-flops. The intension is to have registers
with better metastability properties to improves the MTBF.
As many ASIC designs use clock gating very extensively, particular care
has be taken for this aspect as well.
Thank you for the quick response.
1. Are there special FPGA registers (with better metastability
properties) designated for CDC?
2. Can you please elaborate on your last statement?
Also, any other opinions/comments?
Author: Sym (Guest)
As far as I know, no. At least not with Xilinx, Altera, Microsemi,
Lattice. However, you can tell the tools to treat CDC registers
differently in a sense, to avoid register duplication/merge, pipelining
and retiming on the first 2/3 registers of the synchronizer. This way
the MTBF improves.
Clock gating disables clocks for power saving - a very common feature in
today's SoC designs. When disabling clocks, synchronization of handshake
signals or gray pointers may take longer (due to disabled clocks) and
need to be taken into consideration. That's not different as for an
FPGA, yet clock gating on an FPGA is less common.
  • [vhdl]VHDL code[/vhdl]
