Forum: FPGA, VHDL & Verilog reduce procedure/function parameter list
von bumo (Guest)
I am currently working on a testbench which consists of several
procedures.
The problem i am facing is that, even for small blocks embedded in
procedures, the number of parameters is very high if i have to loop them
back.
This makes the procedure parameter list very complicated to read/write
and even worse, the code harder to understand.
eg (useless, but shows the problem)
  procedure foo (
    signal clk        : in  std_logic;
    signal a0         : in  std_logic; -- loop signal in
    signal a1         : in  std_logic;
    signal b0         : out std_logic; -- loop signal out
    signal b1         : out std_logic) is
  begin
    wait until rising_edge(clk);
    b0 <= a0;
    b1 <= a1;
    b0 <= '0';
    b1 <= '0';
  end procedure foo;
Is there a way to bypass this problem, eg by accessing signals from from
the testbench begin section from within the procedure? (I am aware of
the fact that this would lead to unportable code...)
Thank you in advance.
von bumo (Guest)
Although I had to change a lot, I ended up using a record.
von VHDL hotline (Guest)
Have you tried using "inout" for the same signal instead of separate in
and out?
von bumo (Guest)
The signals are from different sources, therefore inout is no option.
However, I had to use inout for the record, since signals are
read/written.
I figured that this also leads to subtile problems. Since the record is
used with inout, it does not seem to be possible to write to a signal
within the record from a different process, even if it is only written
in a single process?!
von daniel__m (Guest)
hi,
maybe "impure" can help you.
also maybe it is helpful declaring the procedures/functions within the
process, which uses them.
von bumo (Guest)
daniel__m wrote:
> hi,
thanks, i was not aware of the "impure" keyword.
Very strange, when the signal within the record, which is shown as
multiple driven in the simulator is initialized with high impedance,
everything works fine...
von Duke Scarring (Guest)
I think there where some inprecise formulations in the VHDL standard a
while around.
In my modelsim.ini I find the following section:
; Determine how mode OUT subprogram parameters of type array and record are treated.
; If 0 (the default), then only VHDL 2008 will do this initialization.
; If 1, always initialize the mode OUT parameter to its default value.
; If 2, do not initialize the mode OUT out parameter.
; Note that prior to release 10.1, all language versions did not initialize mode
; OUT array and record type parameters, unless overridden here via this mechanism.
; In release 10.1 and later, only files compiled with VHDL 2008 will cause this
; initialization, unless overridden here.
; InitOutCompositeParam = 0
You also have to check how your synthesizer works on that point.
Duke
von bumo (Guest)
> while around.
> Duke
Thanks for pointing that out, I will have a look.
