Forum: FPGA, VHDL & Verilog Implementation error due to UCF FILE (MOJO)
Author: George Saman (Company: nonne) (georgesaman)
I get it this error when i generate bin file, I am using Xilinx ISE and
it shows that the synthesize part is done. I am new to VHDL and FPGA
development.
Resolving constraint associations...
Checking Constraint Associations...
ERROR:ConstraintSystem:59 - Constraint <NET "led<6>" LOC = P124 ;>
   [D:/MOJO/verilog/mojo-base-project-master/mojo-base-project-master/src/m
ojo.u
   cf(12)]: NET "led<6>" not found.  Please verify that:
   1. The specified design element actually exists in the original
design.
   2. The specified object is spelled correctly in the constraint source
file.
WARNING:ConstraintSystem - A target design object for the Locate
constraint
   '<NET "led<6>" LOC = P124 ;>
ojo.u
   cf(12)]' could not be found and so the Locate constraint will be
removed.
ERROR:ConstraintSystem:59 - Constraint <NET "led<7>" LOC = P123 ;>
ojo.u
   cf(13)]: NET "led<7>" not found.  Please verify that:
design.
file.
constraint
   '<NET "led<7>" LOC = P123 ;>
ojo.u
   cf(13)]' could not be found and so the Locate constraint will be
removed.
Done...
Checking expanded design ...
Partition Implementation Status
  No Partitions were found in this design.
NGDBUILD Design Results Summary:
  Number of errors:     2
  Number of warnings:   2
Total memory usage is 192172 kilobytes
Total REAL time to NGDBUILD completion:  21 sec
Total CPU time to NGDBUILD completion:   21 sec
One or more errors were found during NGDBUILD.  No NGD file will be
written.
Writing NGDBUILD log file "gates2_top.bld"...
Author: Duke Scarring (Guest)
> ojo.u
> design.
> file.
You need to set a signal to outputs led<6> and led<7> in your code:
module ...
led[6] <= '1';
led[7] <= '0';
endmodule
If you have no signal assignment than the signal will be optimized away.
Duke
  • [vhdl]VHDL code[/vhdl]
