Forum: FPGA, VHDL & Verilog Lcdtft application is not working
von vijaya lakshmi (Guest)
    I am trying to interface Lcd tft display via SPI  with my custom
board. I'm using Spartan 6 (part number :: XC6SLX9, speed grade :: -2,
package ::  csg324). My initialization part, data sending part are
proper in simulation, but I am not getting any pattern on my Lcd
display.
     Where I suppose to check to debug the error..??
Thanks & Regards,
Vijji
First step ist to read the toolchains errors and warnings. If there are
any you don't know what they mean and you are unsure about ignoring
them, then you must check them thoroughly until you are really sure that
you can go on with that message.
When simulation is ok, then you must check wether your hardware shows
the same behaviour. So a logic analyzer to analyze the data stream would
be the best...
But keep in mind: its very, very (indeed stupidly) easy to write HDL
code that simulates properly and fails on hardware immediately.
What HDL?
Maybe you can simply post those files as *.V or *.VHD attachments here.
Its fairly easy to recognize critical parts in a beginners code... ;-)
von Vanvouver (Guest)
If there is no output at all, this is caused in the most cases by one of
the following reasons:
- No clock is available. Make a design that connects the clock signal
directly to one of you outputs and check you can see a clock there.
- The design is in an continuous reset state due to false polarity of
the reset signal.
- You forgot to constrain your signals to the correct FPGA pins. Check
this first since it may damage your hardware.
Are you on an eval platform, or some other hardware? is the board proved
to work in general?
von Vijaya K. (vijji148)
Hi Vanvouver,
  FPGA Board is working fine. I constrained signals properly.
  I generated reset in the top module itself, I didn't constraint reset
signal.
  The attached file is nothing but waveforms of SPI and fsm_controller.
check it once..
Thanks & Regards,
K Vijaya Lakshmi
: Edited by User
> My initialization part, data sending part are proper in simulation
So, theres no use in sending screenshots from that.
Did you read my post?
> check it once..
Against WHAT? No one else but you knows anything about that "LCD with
SPI interface". So maybe the timing is ok, or maybe not. Who can know?
> check it once..
You should do that. Didn't you?
Hi Lothar,
   I will do it from scratch . I will keep in mind what you told,  As
per your suggestion I will use logic analyzer to analyze the data stream
Thanks & Regards,
Vijji
von Dajana K. (hummer90)
Check the lcdtft timing requirements. Maybe you send your spi frames to
fast or you need to implement an initialization that your lcd can
identify an open communication.
I had the same problem with my atmega a few days ago...
von Vancouver (Guest)
Vijaya,
as Lothar said, it is useless to post simulator screenshots here as you
simulation is working, but your hardware is not.
Did you check the presence of a clock signal at the output pins?
What kind of clock source are you using in your simulation model and in
the real hardware?
How do you generate the reset signal, is it from an external pushbutton
oder generated from an internal counter?
Did you prove there are any signal forms at the FPGA outputs? Did you
check whether the clock frequency conforms to the LCD's data sheet?
  I couldn't able to debug my project. The following attached files are
related to my project. Kindly, help me to point out the error.
 Any help would be appreciated.
Thanks & Regards,
Vijji
