Forum: FPGA, VHDL & Verilog Machx02 User Flash Memory
Author: Chris Customchris (customchris)
Hi guys, I just can't seem to wrap my head around this one, I would like
to implement the user flash into my project to use like eeprom, I'm
hoping someone has a very basic example, like std_logic_vector of 15
down to 0 "input" and the same for "output", upon button press input is
locked in memory for use on power up at "output".
I've read the app notes from Lattice, I just can't visualize how to
create this, would be fantastic if there was a simple example, just like
a blink sketch or hello world.
Thank you guys.
Looks like I might just have a better chance at interfacing NVSram or
spi flash/eeprom. Not enough examples to help me understand how to use
this feature, I can't even figure out how to use the softcores out
there.
Author: Holger (Guest)
Hello here is hint for you how to use IPexpress
http://datasheet.octopart.com/LCMXO2-4000HC-4TG144...
EFB Module in IPexpress
Page 138.
I send you later more info how to bind the ipexpress module *.ipx in
your project
und compile it with a simple RTL modules.
Greetings Holger.
> your project
Task 2: Create an IPexpress Module at Page 16-<....
Click Import IPX to Diamond project.
Link:
https://www.google.de/url?sa=t&rct=j&q=&esrc=s&sou...
This is for a siple pll module via IPexpress,(binding in a project)
 but you see more resources for your Hardended Machxo2 Chip. EFB.
SPI I2C TIMER ect.pp.
Geetings Holger.
This looks promising, thank you, every bit helps.
Yeah none of this is making any sense, its not clear enough on how to
generate the Ipexpress efb and whatever is needed to get UFM, every
document is very vague about what to do, and just about every paragraph
tells you to look into a different pdf to learn something else, it all
seems to be a vicious circle of info for those who already know how to
interact with the ise and import files/work the ports, Im coming from
arduino environment where there are very well written and explained
examples, I've somehow been able to get my project very well where it
needs to be and it performs fantastically, in the beginning i taught
myself how to add a very crude spi function to read a device with timers
feeding timers that ran a When case, in the when case i controlled the
Chip select, Mosi, Miso, and the Serial clock, with the help of a nifty
logic analyzer i was able to see these lines and adjust to mimic what
was shown in the datasheet for a spi transaction. the only thing im
missing is a single on the fly adjustable  16bit memory location.
I'm to the point where im willing to hire someone to help me out, if my
boss and i cant figure this out tomorrow, this is vital to finishing my
project, and i really would like to learn this, seems be a huge lack in
lattice fpga tutorials and examples, xilinx is so plentiful in examples
but none of which that i have found are in the Non Volatile platforms
with internal flash.
  • [vhdl]VHDL code[/vhdl]
