Forum: FPGA, VHDL & Verilog troubles with VHDL testbench in Modelsim
Author: Dima Ustinoff (ustinoff)
Hello everyone!
I have a problem: i've tried to simulate my project by the testbench,
but Modelsim wrote next message:
Error: C:/.../testbench.vhd(62): (vcom-1136) Unknown identifier "arst".
And the same message for each other ports of testbench's component.
Also, next one type of messages, for internal signals of testbench:
Error: C:/.../testbench.vhd(63): (vcom-1484) Unknown formal identifier
ARST_STIM
Top-entity "top_test" and each other entities in one common folder with
testbench, so i do not understand what is a reason of the problem. I've
posted the code of my testbench below:
-- Created:
--          by - Desmond.UNKNOWN (DESMOND-PC)
--          at - 00:52:37 07.03.2016
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY testbench IS
END testbench;
ARCHITECTURE rtl OF testbench IS
   -- Architecture declarations
   -- Internal signal declarations
   -- Component declarations
   COMPONENT top_test
      PORT (
         arst             : IN     std_logic;
         bithigh          : IN     std_logic_vector(31 DOWNTO 0);
         bitlow           : IN     std_logic_vector(31 DOWNTO 0);
         ca_bh10          : OUT    std_logic;
         ch_ca_data       : IN     std_logic_vector(31 DOWNTO 0);
         ch_s             : IN     std_logic_vector(31 DOWNTO 0);
         clk120MHz        : IN     std_logic;
         clk240Mhz        : IN     std_logic;
         clock_value_high : IN     std_logic_vector(31 DOWNTO 0);
         clock_value_low  : IN     std_logic_vector(31 DOWNTO 0);
         dac_1            : OUT    std_logic_vector(15 downto 0);
         dac_2            : OUT    std_logic_vector(15 downto 0);
         freq_setup       : IN     std_logic_vector(31 DOWNTO 0);
         led              : OUT    std_logic;
         level            : IN     std_logic_vector(31 DOWNTO 0);
         out_symb         : OUT    std_logic;
         pps              : IN     std_logic
   END COMPONENT;
signal LED,CA_OUT,MOD_OUT : std_logic;
signal ARST_STIM,CLK_120MHZ,CLK_240MHZ,PPS_STIM : std_logic := '0';
signal BIT_HIGH_STIM,BIT_LOW_STIM,LEVEL_STIM,CA_DATA_STIM,FREQ_STIM,CLK_LOW_STIM,CLK_HIGH_STIM,CH_SELECT_STIM : std_logic_vector (31 downto 0);
signal DAC_1, DAC_2 : std_logic_vector (15 downto 0);
constant CLK_120MHZ_PERIOD : TIME := 8.33 ns;
constant CLK_240MHZ_PERIOD : TIME := 4.15 ns;
BEGIN
 U_0 : top_test
 PORT MAP (
ARST_STIM => arst,
CLK_120MHZ => clk120MHz ,
CLK_240MHZ => clk240Mhz,
PPS_STIM => pps,
BIT_HIGH_STIM => bithigh ,
BIT_LOW_STIM => bitlow,
LEVEL_STIM => level,
CA_DATA_STIM => ch_ca_data,
FREQ_STIM => freq_setup,
CLK_LOW_STIM => clock_value_low,
CLK_HIGH_STIM => clock_value_high,
CH_SELECT_STIM => ch_s,
DAC_1 => dac_1,
DAC_2 => dac_2,
CA_OUT =>  ca_bh10,
LED => led,
MOD_OUT => out_symb
CLK_GENERATION : process
begin
CLK_120MHZ <= not CLK_120MHZ after (CLK_120MHZ_PERIOD/2);
CLK_240MHZ <= not CLK_240MHZ after (CLK_240MHZ_PERIOD/2);
end process CLK_GENERATION;
STIM_PROC : process
begin
ARST_STIM <= '1';
PPS_STIM <= '0';
wait for 100 ns;
CH_SELECT_STIM <= (others=>'0');
CLK_LOW_STIM <= "00010111010110001110001000011001";
CLK_HIGH_STIM <= "00000000000000000000000000000001";
FREQ_STIM <= "00000010001000100010001000100010";
LEVEL_STIM <= "00000000000000000000000000110010";
CA_DATA_STIM <= "00000000000000000000000000000110";
BIT_LOW_STIM <= "00100110100101111011000000000000";
BIT_HIGH_STIM <= "10101010010010111110100001010101";
wait for 1800 ns;
PPS_STIM <= '1';
wait for 100 ns;
PPS_STIM <= '0';
wait for 1000 ns;
CH_SELECT_STIM <= "00000000000000000000000000000001";
wait for 999999000 ns;
PPS_STIM <= '1';
wait for 100 ns;
PPS_STIM <= '0';
wait for 10000000 ns;
end process STIM_PROC;
END rtl;
UPD: So, i understood: arts => ARST_STIM, and each other too.
: Edited by User
Right. The assignment sequence inside the PORT MAP is
ComponentPort => ConnectingSignal
  • [vhdl]VHDL code[/vhdl]
