Forum: FPGA, VHDL & Verilog Bitwise OR of std_logic_vector
Author: Hamidreza Ahmadian (Company: Uni Siegen) (ahmadian)
Hello,
Suppose we have 4 buffer, each has a single bit which indicates if the
buffer is empty and we connect this pin to the bellow signal.
signal buffer_empty       : std_logic_vector (3 downto 0);
Each bit of the above signal indicates whether the corresponding buffer
is empty or not and the below signal indicates whether we have an empty
buffer al all.
signal any_buffer_empty   : std_logic;
The second signal can be assigned as follows:
any_buffer_empty <= buffer_empty (0) and buffer_empty (1) and
buffer_empty (2) and buffer_empty (3);
Now the problem gets difficult for me if the number of buffers is
parameterized (by a generic or constant like NR_BUFF) and I cannot
figure out how to calculate the second signal in this case.
Thanks in advance,
Hamid
Hamidreza A. wrote:
> and I cannot figure out how to calculate the second signal in this case.
Check out the package reduce_pack and in there the functions or_reduce()
as well as and_reduce().
See this also:
http://www.edaboard.com/thread253196.html
: Edited by Moderator
Author: Stefan Weide (Guest)
1 useful
You can also use the following
  -- bit-wise or
  any_buffer_empty <= '0' when buffer_empty=(buffer_empty'range=>'0') else
                      '1';
  --bit-wise and
  all_buffer_empty <= '1' when buffer_empty=(buffer_empty'range=>'1') else
                      '0';
  • [vhdl]VHDL code[/vhdl]
