Forum: FPGA, VHDL & Verilog Timing Requirements - Worst case Removal Slack
Author: Bryan (Guest)
Hallo all,
I have a critical warning of Worstcase removal slack of -2.461.
From node: - altera_reserved_tck
To node:   pzdyqx:nabboc|pzdyqx_impl:pzdyqx_impl_inst|FNUJ6967
I am not sure if I should ignore this warning as the path is the open
core plus logic and it should constrain itself and since it operates on
the slow JTAG clock
So the reason I see the failures is that the logic isn't constrained and
not necessarily true failing paths. Unfortunately those are randomized
names so you can't add in your own constrains easily. Since I use OCP,
maybe it shows up as a failing path.
Any suggestions? Should I ignore it or fix it?
Thanks!
Author: Markus F. (mfro)
> Thanks!
https://www.altera.com/support/support-resources/k...
  • [vhdl]VHDL code[/vhdl]
