Forum: FPGA, VHDL & Verilog Blocking cammand Implementation Question
Author: guitardenver (Guest)
I have a question about blocking commands in an always block in verilog.
For the simple code snippet below:
always @(posedge clk) begin
    address <= address + 1;
end
always @(address) begin
    data = data | 8'h04;
end
My question is:
How can I guarantee that the "data = data | 8'h04;" is completed before
the "address" changes on the next positive edge of the clock?
My solution (But with question about it):
    //Only increase the address if the computation is complete
    if(!computingFlag) begin
    end
end
    computingFlag = 1'b1;
    computingFlag = 1'b0
end
In the above I set a flag telling the address to not increment until the
computation is done.
Questions:
1) But is it guaranteed that the blocking statements will execute one
after another? The next will never execute till the first is over?
2) What if the "data = data | 8'h04;" statment was a computation that
completed so fast that the computing flag did not have enough time to
actually rise and fall? I'm talking about the physical limitation of the
hardware (it's speed). Or does the synthesizer guarantee that the
"computingFlag" will get to steady state before the next line is
implemented?
3) How can you tell if an always block will be executed one after
another instead of synthesizing into combinational logic?
Thank you for the insight
Matt
Author: Lattice User (Guest)
Easy answer: It will always be synthesized into combinational logic!
On Hardware there ist no such thing as an execution engine which
executes your code line by line.
That makes sense. The resources i've been reading where a little
confusing on that then. I'm guessing now that if I tried to synthesized
that, it would give an error then because i'm assigning "computingFlag"
to two different values at the same time.
Any suggestions on how to solve the problem? How do I make sure that the
computation is finished before it increments to the next address?
To be more specific on the computation:
end
    ram[address] = ram[address] | 8'h04;
end
The computation is simple but it could be replaced by anything that
would take multiple clock cycles to complete.
guitardenver wrote:
> How do I make sure that the computation is finished before it
Your clock must be slow enough...
In fact: have a look what you have in the real world:
1) logic gates (in FPGA represented by LUTs) and
2) flipflops
And so your question must be:
How can I make sure that the flipflop has valid input?
And the answer is:
The input must be stable (well) before the clock edge!
Then you have a "multi cycle path" and you must tell this to the
synthesizer with according timing constraints.
You have a look how long the computation lasts and then you add a
counter to your design thats waits long enough by coounting some clock
cycles...
Or you break up the calculation and add some flipflops in your design
(=register balancing) to generate a pipeline structure and deal up the
slow logic against a calculation needing some clock cycles.
With such a strategy you will have a completely synchronous design in
which can get a new computation result with each clock. The only thing
is that then each result is delayed several clocks.
Another attempt:
I learned that when using blocking assignments that the right side of
the statement for every statement is computed, and only when they are
all realized, the data is then clocked in to the registers. Is this
true? Is it garunteed or does it depend on what blocking statements are
in the always block?
If the above is true here is my next attempt at conceptualizing this.
The address can only be incremented if "computingFlag" is 0, and I know
that the Block 2 (labled below) will complete before the next clock
cycle because it's such a small operation. The "computingFlag" will only
be cleared once all the right side of the blocking statments in Block 3
are realized. This means the computation is completly finished before
the result of both the computation and the computingFlag is written
(clocked in) to the registers. Which means Block 1 will not increment
the address until all of block 3 is completely finished.
Is this a legitimate way to do this?
//Block 1
    end
end
//Block 2
end
//Block 3
always @(computingFlag) begin
    if(computingFlag) begin
      computingFlag <= 1'b0;
      ram[address] <= ram[address] | 3'b100;
    end
end
Sorry,
I meant "nonBlocking" statements in the first paragraph not "blocking"
Well I might of answered my own question.
The computation in Block three will be combinational logic that will be
connected to the registers inputs. But the computation will still have
to propagate to steady state before the next clock cycle when the
results of block 3 are clocked in (the non-blocking part). The
non-blocking statement does not and can not wait for all the logic to
get to steady state before it clocks in the results. Which I guess is
why never using non-blocking statements with combinational logic on the
right side is good practice.
guitardenver wrote:
> The non-blocking statement does not and can not wait for all the logic
> to get to steady state before it clocks in the results.
In real life nothing is "waiting" for anything to be "stable" or
"steady". In real life theres some kind of logic in front of a flipflop.
And behind that flipflop ist some kind of logic followed by a flipflop.
And so on.
Thats all.
And that "computing_flag" in your example above is simply optimized to
0 and vanishes to nowhere. Just have a look for the RTL schematics after
synthesis...
: Edited by Moderator
Forget about using blocking assignments for controlling the flow. IT
DOES NOT WORK. Same goes for sensitivy lists on combininatorial always
blocks. They are only there to aid the simulator and will be ignored by
the synthesys tool.
Some rule of thunb for creating synthesizable code which simulates
correctly:
1. The sensitivity list for a sequential always block must only include
one clock and optional one reset. You have to specify posedge or negedge
on both signals.
2. The sensitivity list for a combinatorial always block must be
complete and must not contain a posedge or negedge operator.
3. Use only non-blocking assignments in sequential always blocks.
4. Use only blocking assignments in combinatorial always blocks.
5. Don't use any signal in a combinatorial always block on both sides of
the assignement operator.
Not follwoing these rules will result in either failing to synthesize or
worse creating code which behaves differently in simulation and on
hardware. (so called simulation mismatch)
This should solve your problem:
end
Try to understand why, read about RTL (Register Transfer Level) coding.
Also consult the coding style guidelines of your toolchain.
PS: to describe a real ram on a FPGA you need to read the coding style
guildlines of your toolchain. The above will most likely fail and just
create a large amount of flipflops.
Thanks guys!
  • [vhdl]VHDL code[/vhdl]
