Forum: FPGA, VHDL & Verilog help error 10822 vhdl
Author: daniel (Guest)
i will be thankful if somebody will can help me..
my aim is to make a block that get 3 inputs:
a clc that change every 0.1 sec
a input that get '1' every time i press key0
and reset button that reset my count
the aim is to count the number of time i press and when there is 3 secs
that i dont press i get the count of the time i pressed
i tried to it with this code"
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity CLAPNUM is
   port(
    resetN, clk : in std_logic;
    key0         : in std_logic   ;
    sinus      : out  std_logic_vector(4 downto 0));
end CLAPNUM ;
architecture arc_CLAPNUM of CLAPNUM is
signal countera : std_logic_vector(4 downto 0) :="00000"  ;
signal counterb : std_logic_vector(4 downto 0) :="00000" ;
signal cinout   : std_logic := '0' ;
signal moda   : std_logic := '0' ;
begin
process ( resetN key0, clk)
  begin
    if resetN = '0' then
    countera<="00000" ;
    counterb<="11110";
  elsif (key0 ='1') and moda='0' then
    countera<= countera+"00001" ;
    counterb<="11110";
  elsif (rising_edge(clk))  then
    if counterb/="00000" and (key0 ='0') then
      counterb <= counterb-"00001";
    else
      moda <= '1';
    end if;
  elsif moda='1' then
  sinus<= countera;
  end if;
   end process;
end arc_CLAPNUM;
but clearly it dosent work...
can someone help me plz?
: Edited by Moderator
First have a look at the attached sreenshot...
And HOW did you see that?
Did you do a SIMULATION?
What ERROR messages or WARNINGS did you get?
And why do you ignore them all?
In fact the problem here is the well known and famous "combinatorial
loop":
as long as key0 is 1 and moda is 0 the countera is counting upwards
without any clock at maximum and random speed:
Try Google translator on that:
http://www.lothar-miller.de/s9y/archives/42-Kombin...
Let me ask you: where did you see this structure in literature?
begin process ( resetN key0, clk)
begin
end if;
There's only one way to desrcibe a synchronous process:
begin process ( resetN, clk)
begin
end if;
Beside the whole things above: the sensitivity list is incomplete, moda
ist missing. Therefore a simulation will show wrong results...
BTW: congratulations to use the 1-process-FSM. You are a big step
further than in the thread https://embdev.net/topic/386779
  • [vhdl]VHDL code[/vhdl]
