Forum: FPGA, VHDL & Verilog how to use clk in fsm
Author: daniel (Guest)
I want to build a final state machine embodies eight numbers and then
she proceeded to tell the eighth.
For example if  the  eight number  is four I want the machine extract
four pulses of 1 clock cycle difference between between pulses and then
wait another 10 clock cycles and then switches to the next state( and in
the next do the same thing).
The problem that he dosent let me use the clock in the states ..
Does anyone have an idea what to do?
The code
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity pulsim is
   port(
    resetN, clk : in std_logic;
    da         : in std_logic_vector(3 downto 0) ;
        db         : in std_logic_vector(3 downto 0) ;
        dc         : in std_logic_vector(3 downto 0) ;
        dd         : in std_logic_vector(3 downto 0)  ;
        de         : in std_logic_vector(3 downto 0)  ;
        df         : in std_logic_vector(3 downto 0)  ;
        dg         : in std_logic_vector(3 downto 0)  ;
        dh         : in std_logic_vector(3 downto 0)  ;
    sinus      : out  std_logic);
end pulsim ;
architecture behavioral of pulsim is
type state_type is (s0,s1,s2,s3,s4,s5,s6,s7);
signal current_s,next_s: state_type;
signal countera : std_logic_vector(4 downto 0) :=dh &'0' ;
signal counterb : std_logic_vector(4 downto 0) :="01010" ;
signal cinout   : std_logic ;
begin
process ( resetN , clk)
   begin
    if resetN = '0' then
        current_s <= s0;
  elsif (rising_edge(clk)) then
  current_s <= next_s;
  end if;
   end process;
process (current_s,dh,clk)
begin
  sinus <= cinout ;
  case current_s is
     when s0 =>        --when current state is "s0"
     if(dh ="1111") then
      cinout <= '0';
      next_s <= s0;
   else
    if clk='1' then
      if countera /= "00000" then
        countera <= countera-"00001";
        cinout<= not(cinout);
        counterb<="01010";
      elsif (countera = "00000") and (counterb/="00000") then
          counterb <= counterb-"00001";
          cinout <= '0' ;
      else
      counterb<="01010";
      countera<=dg &'0';
      next_s <= s1;
      end if;
    end if;
  end if;
  when s1 =>
    if rising_edge(clk) then
        cinout <= not (cinout) ;
        counterb<="01010";
          cinout <= '0' ;
      else
      counterb<="01010";
      countera<=df &'0';
      next_s <= s2;
      end if;
    end if;
  when s2 =>
        counterb<="01010";
          cinout <= '0' ;
      else
      counterb<="01010";
      countera<=de &'0';
      next_s <= s3;
      end if;
    end if;
    when s3 =>
        counterb<="01010";
          cinout <= '0' ;
      else
      counterb<="01010";
      countera<=dd &'0';
      next_s <= s4;
      end if;
    end if;
    when s4 =>
        counterb<="01010";
          cinout <= '0' ;
      else
      counterb<="01010";
      countera<=dc &'0';
      next_s <= s5;
      end if;
    end if;
    when s5 =>
        counterb<="01010";
          cinout <= '0' ;
      else
      counterb<="01010";
      countera<=db &'0';
      next_s <= s6;
      end if;
    end if;
    when s6 =>
        counterb<="01010";
          cinout <= '0' ;
      else
      counterb<="01010";
      countera<=da &'0';
      next_s <= s7;
      end if;
    end if;
    when s7 =>
        cinout<= not (cinout) ;
        counterb<="01010";
          cinout <= '0' ;
      else
      counterb<="01010";
      countera<=dh &'0';
      next_s <= s0;
      end if;
    end if;
  end case;
end process;
end behavioral;
: Edited by Moderator
In fact its a "finite" state machine. That means: this machine only has
a limited number of states. The opposite would be a machine with
uncountable sates, a machine with "infinte states"...
You have a VERY, VERY strange way of using a clock. Can you show me any
example doing it a similar way?
No?
Correct. The only way to use a clock for synthesis is at the very
beginning of a process. And additionally you should (for beginners
"must") have only one clock sensitive to the same edge throughout.
And now simply have a look how others did that thing with those FSM.
A hint: a "rising_edge(clk)" involves a flipflop. And that's the state
memory.
Additionally you need some logic to calculate the next state.
That's all...
One is fairly easy to see: you did programming in C previously. And now
you want to "program" with VHDL. But if that was a "programming
language", then it would be VHPL...
So up to now you have the wrong way of thinking: you think in software,
but you must think in hardware. And then you can "describe" your
thoughts.
BTW: did you see the "formatting options" for VHDL code a few lines
above the text edit box? Use it. Its magic...
Initialization with a non constant values is NOT synthesizeable (the
init value can't be predicted by the synthesizer!!!):
Now lets have a second look at your code. And there its easy to see the
usual beginners problems with the 2-process-FSM: you have a
combinatorial process and a process for the flipflops. But when you want
to count, then that counter itself is (the simplest way of) a FSM. And
each FSM has: flipflops and logic. And as that counter is an FSM also,
it must have flipflops and logic.
As i said previously you will get flipflops when you use a
"rising_edge()" (or a "falling_edge()" or a "'event"). Yo tried to
involve that into your combinatorial process, and now you have two
processes generating flipflops. Thats not the intention of writing a
2-process-FSM.
What to do now?
1. use the 2-process-FSM further on.
Then you will have to kick out the clk of the combiunatorial process,
and to invoke some signals like countera_next and counterb_next. And you
will have to calculate the "next" value in the combinatorial process and
you will have to transfer the "next" counter values to countera and
counterb in the clocked process.
2. use the 1-process-FSM.
Then you will have to kich off those "next" values and you will have to
invoke the clock to the combinatorial process.
Heres your problem analyzed:
http://www.lothar-miller.de/s9y/archives/43-Ein-od...
Try it with Google translator, its German...
As a result it will look this way as a 1-process-FSM:
signal state: state_type;
signal countera : std_logic_vector(4 downto 0) :="00000" ;
begin
sinus <= cinout ;
process (clk)
begin
  if (rising_edge(clk)) then  -- the one and only clock
   case state is
     if(dh ="1111") then
      cinout <= '0';
      next_s <= s0;
     else
        counterb<="01010";
          cinout <= '0' ;
      else
      counterb<="01010";
      countera<=dg &'0';
      next <= s1;
      end if;
     end if;
   when s1 =>
        counterb<="01010";
          cinout <= '0' ;
      else
        counterb<="01010";
        countera<=df &'0';
        next <= s2;
      end if;
    when s7 =>
        counterb<="01010";
          cinout <= '0' ;
      else
        counterb<="01010";
        countera<=dh &'0';
        next_s <= s0;
      end if;
    end case;
  end if; -- the one and only clock
end process;
end behavioral;
BTW: I strongly recommend to use the numeric_std lib instead of that old
Synopsis libs...
http://www.lothar-miller.de/s9y/categories/16-Numeric_Std
I also strongly recommend using integers for counting. Its FAR WAY
easier to read this here:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
signal countera : integer range 0 to 10 := 0;
signal counterb : integer range 0 to 10 := 10;
    when s7 =>
      if countera /= 0 then
        countera <= countera-1;
        counterb <= 10;
      elsif (countera = 0 and (counterb /= 0) then
        counterb <= counterb-1;
        cinout   <= '0' ;
      else
        counterb <= 10;
        countera <= to_integer(unsigned(dh))*2;
        next_s   <= s0;
      end if;
And as you see I also strongly recommend to use indetion to get an
easily readable code...
  • [vhdl]VHDL code[/vhdl]
