Forum: µC & Digital Electronics Wrong value received in SPI receive register
Author: Aditya K. (stadkama)
Hello,
I am building an SPI communicaton between MCU-ATSAM4E8C (master) and
Slave device -bmi160 inertial sensor.
Debugger -atmel ice and MCU Device Programming Interface- jtag.
Issue:
1.During debugging, the receive data register always shows 0xff in the
receive register(spi_rdr) even though the inertial sensor is sending
0xd1 that I verified in oscollocope.
2. During debugging , the Receive data register full bit(RDRF) is not
set. However if I don't debug and check using if condition the bit will
be set.
Please let me know what is the cause for this issue.
Thank you.
Author: Jim Meba (turboj)
Reading the RDR register with the debugger clears the RDRF bit. Thats
why I told you not do do that: https://embdev.net/topic/383997#4382228
Yes you had mentioned the below. I have a question.
>1. Reading spi_RDR in debug window is potentially harmful: This is a
>hardware register where reading has side effects!
>2. While you are debugging SPI code, save those registers into a variable
>that you can safely read with the debugger."
   I had assigned the receive register to a variable. Even though it is
not showing correct value. Please find the code below.
spi_read_status spi_read(Spi *p_spi,uint8_t *pcs, uint16_t *data)
  static uint32_t register_value;
  uint32_t timeout = SPI_READ_TIME_OUT;
  while (!(p_spi->SPI_SR & SPI_SR_RDRF)) {
    //if timer expires return timeout.
  register_value = p_spi->SPI_RDR;
  if (spi_get_peripheral_select_mode(p_spi)) {
    //get the pcs value here from the spi_rdr
  *data= (uint16_t) (register_value & SPI_RDR_Mask);
  return SPI_READ_OK;
Please clarify whether my understaning here is correct or not. Did you
mean that I can't  debug and test in this way. Thank you.
: Edited by User
Author: fop (Guest)
Begin with the simple faults :
Be sure to connect your osci directly at the microcontroller pin. So you
can't be tricked by bad solder joints.
Verify that you use the right pin as MISO.
I never used JTAG on Atmels - is there no interference between Debugger
and SPI ? I ask because programming is done via SPI pins on AVRs.
 On atsam device there are only 2 interface to program/debug the micro
controller i.e. jtag and swd. Is this reason why I am not able to see
the proper values in the receive register during debugging?
 Because all other suggestions u had mentioned is working fine.
