Forum: FPGA, VHDL & Verilog Can't compile duplicate declarations of entity "xyz" into library "test"
Author: Hugo Hirsch (Company: Veri) (hugo17)
When I compmile my project in Quartus (15.0 Webedition) I get following
error message:
When I click on the error message it opens the file "xyz.v". What I see
is the Verilog-file although the project only uses vhdl-files! There is
allready a file with the name "xyz.vhd" in the project.
Under Settings -> Files there are only vhdl-files included. Now I am
wondering why the compiler still sees a Verilog-File.
Thanks in advance!
Hugo H. wrote:
> Now I am wondering why the compiler still sees a Verilog-File.
Do you have some kind of precompiled core in your system (e.g. a divider
or a multiplier or somewhat else)?
No. I am using a Nios and two other blocks (QSYS) like an SPI interface
and some I/O - that's all.
What I changed in the meantime is the IP Settings -> IP generation HDL
preference to VHDL. Now I get following error message:
10430 VHDL Primary Unit Declatation erro at xyz.vhd: primary unit "XYZ"
already exists in library "xyz". A click of this file opens (again) the
xyz.vhd (not Verilog file!).
But in my project I have the file "XYZ.vhd" (capitol letters). Therefore
it is quite the same problem again. Why quartus generates such file in
the database which is almost the same as my file in the project folder
which has a reference in other files?
  • [vhdl]VHDL code[/vhdl]
